Engine differences - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 07-06-2014, 01:50 PM Thread Starter
Default Engine differences
Looking at getting a Vic Hammer or Jackpot and noticed a big difference in used prices if the earlier 08-09 100/5sp models. What was the upgrade in output and does the extra gear really warrant the $1000 price gap. Had a 106/6sp Veagas before and loved it.
2008 Suzuki B King,2010 Vegas 8 Ball,2006 BMW Z4.
goon is offline
post #2 of 11 (permalink) Old 07-06-2014, 02:27 PM
You also have twice the oil change interval with the 6 speed so factor that into the price plus better gas mileage on the highways. As you see the resale will be higher also if that matters to you. For $1000 difference I would go for the 6 speed but it's your money find the best value for you.
2011 vegas 8ball PCV, swept pipes rpw modified baffles, llyodz vm1-dr cam, ats +4, 1/4 throttle, ud pulley and ness intake.
KMC tuned 114hp/125ft/lbs
shanko is offline
post #3 of 11 (permalink) Old 07-06-2014, 03:54 PM
Garion12's Avatar
Only on 2011 and up. 2010 and below 6 speed had the lower oil change mileage.
2010 Cross Roads
Lloydz Air Filter
Lloydz Slip on Exhaust
Lloydz Timing Wheel 8*
LLoydz VM1-HPT Cams
Lloydz reflesh 6500 rpm
Dyno tuned by KMC 123 hp 121 tq
Garion12 is offline
post #4 of 11 (permalink) Old 07-06-2014, 07:29 PM
Motorbikerx's Avatar
Did you use sixth gear much? And could you live without it?
The only time I can really comfortably pull sixth is over the speed limit here. (OZ)
My 2010 Vegas is a 100/6 . With my breathing mods it generates as much torque as an uncammed 106 , and is a bit down on HP with a 106 . But these bikes are driven more by torque than HP
As for oil changes I do mine midway between the old and new points.
I have no problems selecting neutral which is why Vic specd the early change interval, but as I'm using top quality Aussie oil thats half the price of Vics I tend to change it before the upper change limit.....when you change is up to you
And how your bike is at finding neutral when stationary.
Bottom line its up to you
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #5 of 11 (permalink) Old 07-06-2014, 07:45 PM
robvision's Avatar
What is the difference between the two motors that could possibly make the oil changes so different ?
Maybe they don't spray any oil on the 106 gears? That would make the oil last longer!!
Considering the biggest killer of viscosity is the gears !!!
Rob
2010 V Star 650 Custom (Wife's)
2013 XCT 2013 Suzuki KQ750 AXI Power Steerring
Victory Sport Touring Flag Ship
Lloydz Idle Air Valve
Lloydz PTW
60,000 km
Rear Rack
Passenger Grab Handles
Modified Heel Shifter
HID Low
Oil Temp Gauge
Ride-On TPS
Modified Stock Pipes by Thrush
K&N air filter
G-man Bully FI Controller
Heat Troller
LED Driving lights
PCV with AutoTune
robvision is offline
post #6 of 11 (permalink) Old 07-06-2014, 09:58 PM
See my post above ^^^
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #7 of 11 (permalink) Old 07-06-2014, 10:46 PM
robvision's Avatar
So your saying it's the ease of finding neutral
Victory thinks that if you use neutral at stop lights instead of holding the clutch in that the oil will last twice as long?
I can see less clutch material in the oil but how many people put the bike in neutral waiting for the light to change. Most leave the bike in gear in case they need to make a quick get out of the way.
If this is what it's about......a lot of us need to be changing oil at 2500
Rob
Lloydz PTW
60,000 km
Rear Rack
HID Low
Oil Temp Gauge
Ride-On TPS
K&N air filter
Heat Troller
LED Driving lights
PCV with AutoTune
post #8 of 11 (permalink) Old 07-07-2014, 12:52 AM
I agree with being in gear clutch in at lights.
it's the matter of getting neutral not the reasons why you want it.
I leave my bike running in neutral while I unlock my gate.
Theres more reasons to want neutral that sitting at the lights waiting to be rear ended.
Anyway to me its not a problem.
I'm going for a ride
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #9 of 11 (permalink) Old 07-08-2014, 12:11 AM
Garion12's Avatar
There were several changes to the transmissions between the 2010-2011 model years, not just the neutral assist.
2010 Cross Roads
Lloydz Air Filter
LLoydz VM1-HPT Cams
Garion12 is offline
post #10 of 11 (permalink) Old 07-08-2014, 01:42 AM Thread Starter
Had a 2010 Vegas 8 ball one of the first 6 speed I think no problems with neutral or any shifting,it was spot on.
goon is offline
