ABS light is always on - Victory Forums - Victory Motorcycle Forum
 2Likes
post #1 of 52 (permalink) Old 07-10-2014, 01:21 PM Thread Starter
depot picker's Avatar
Default ABS light is always on
I've been living with this for a long time. I've cleaned the sensors, cleaned and dielectric greased the connectors, shimed the sensors in and out and swapped out the sensors. Every now and then the light will go out for a day or a week or two, but it always comes back on. I really like the ABS when it is working, and it drives me shithouse to have that light on. Anyone have similar issues?
depot picker is offline
post #2 of 52 (permalink) Old 07-10-2014, 02:01 PM
The big question is: Is the ABS actually working when that light is on? I've tested my ABS on a gravel driveway - go about 5 MPH and grab a handful of front brake and release very quickly. Did your wheel slide or did ABS kick in?
post #3 of 52 (permalink) Old 07-10-2014, 02:08 PM
steely610's Avatar
If you grabbed it hard on a normal road and it pulses, isn't that the abs as well broggyr?
2013 Cross Country Tour
steely610 is offline
post #4 of 52 (permalink) Old 07-10-2014, 02:13 PM
Yep, but you'd have to be going quite a bit faster for that to take effect, and that would be one hell of a test...
post #5 of 52 (permalink) Old 07-10-2014, 02:13 PM
CrossRoads's Avatar
To test the ABS, I would apply the rear brake only, on a smooth pavement road. If the wheel locks up, keep it locked until you come to a stop so you do not high side. If the wheel does not lock-up and you feel the brake pulsing, it's working. Make sure nobody's around you or you could get rear ended.
CrossRoads is offline
post #6 of 52 (permalink) Old 07-10-2014, 02:14 PM
That works too, but it's not nearly as fun as my way
post #7 of 52 (permalink) Old 07-10-2014, 02:35 PM
dtmmil's Avatar
my light has been on for sometime also , its on 90% of the time, i havent done anything though besides try keeping it clean, which is hard to do living on gravel. i figured it was a bad sensor
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #8 of 52 (permalink) Old 07-10-2014, 03:19 PM Thread Starter
The ABS only engages when the light is off. I live on a filthy, dusty unmaintained gravel road too.
post #9 of 52 (permalink) Old 07-10-2014, 03:24 PM
steely610's Avatar
I did it today going to work, and it was only like 30 or so, but I grabbed it pretty hard haha
post #10 of 52 (permalink) Old 07-10-2014, 06:27 PM
If the light is on the ABS is not working. Happened to me and required a new sensor.
2012 Victory Cross Country Tour (Black Betty)
2001 Vulcan Nomad (Sold after 85,000 Happy KM's)
Chili is offline
