The difference between AutoTune and professional Dyno Tune - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 07-12-2014, 10:05 PM Thread Starter
Default The difference between AutoTune and professional Dyno Tune
My local shop doesn't have a dyno, so I opted for the AutoTune kit when I had them do my upgrades. After several weeks of adjustments (with a base map from KevinX) I was not happy, and I decided to take it to a professional. As you can see the difference is amazing. I got 12 more ponies to play with and 5 ft/lbs more torque all from a professional tune. Thanks to Brian Livengood at Livengood Motor Sports in Lawrenceville, GA the bike is finally running the way it should.
2015 Victory Gunner
RPW Thor
TTI w/ IAV
ATS 4*
VM1DR
Auto Tune
UncleWeebo is offline
post #2 of 16 (permalink) Old 07-13-2014, 06:10 AM
GatorJoe's Avatar
Nice Numbers and Lines ... Auto Tune is a Fine thing but without a good knowledge of how to accept the Trims to improve it is not going to gain that much .. Pretty Hard to beat a Pro's Tune ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #3 of 16 (permalink) Old 07-13-2014, 07:06 AM
Vicbuilder's Avatar
Very cool!
Now if you had brought it to a Victory specialist he would have noticed that the HP is limited on the top end. The scan is a little fuzzy but it looks like from about 4000-5000rpm the HP goes from a smooth line to a rough line. That generally indicated too little or much timing. Depending on your setup another 2-6 degrees of timing either way would have smoothed that out and gained a few more HP at the top end.
No matter though, you may never notice, and the point is the same, a Power Commander is only as good as the person setting it up! Enjoy!
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
Vicbuilder is offline
post #4 of 16 (permalink) Old 07-13-2014, 09:57 AM
BP6666VR's Avatar
Good stuff mate.... where I live also NO DYNO... so when i ordered my PC-5 and many more upgrades (see signature ) i requested a MAP to suit my bike..... installed everything and it went from "ok" to worse.. so it was a MAP not suitable for my bike, except if you go to a DYNO? .. anyway a forum member Emailed his MAP with the same kind of upgrades, and hopefully my bike will ride "ok" in the future.....
So I think I will have to purchase a LC200 of PC website. so i can actually see what has to be done in the settings .... Air / fuel ratio's etc.
I started collecting MAPS of all kind of Victory's in Indonesia so I can compare them and hopefully make everything work "perfect"
The strangest thing was on the MAPS that at 2500 RPM the timing was +4 when there is a timing wheel already...... so now I have a good MAP and set the timing wheel on +4 and could even go to +6 or whatever as on this MAP it is all on "0"
Cross Country Tour 2014 [B]
BP6666VR is offline
post #5 of 16 (permalink) Old 07-13-2014, 11:14 AM
ndabunka's Avatar
The fact that other peoples MAPS don't (always) work well on YOUR bike should not be a surprise to anyone who has read up on this. You often have to go through 4 or 5 to find something viable for an individual bike.
What the heck is a LC200? If you mean a the Power Commander AutoTune, then that is AT-200 and that is the WRONG one for these bikes as it only has a single O2 sensor. You need the AT-300 in order to monitor the Air-to-Fuel Ration on the PC-V
If you are running a timing wheel @ +4 but you want a total of +6 above 2,000, you will need to reduce the timing in the PC-V from +4 to +2 otherwise you will be @ +EIGHT above 2,500 which might explain why the bike runs like crap
It's not just any victory.... It's MY Victory!
2011 Victory Ness Cross Country #120
Ness Thunderheaders
Ness Knurled Highway Pegs/KwelMetal Brackets
Ness Radius laydown license
Chrome CAM Tension Covers
Red Engine Bolts
Madstad System
DIY Garage Door Opener
Victory Chrome Saddle Bag Lid Rails
Küryakyn Upper Fork Shrouds
Küryakyn Lower Fork Covers
Power Commander V Tuner
Power Commander AT-300
Hertz HCX 165s Speakers
JL Audio HX280/4 Bridged 140w
ndabunka is offline
post #6 of 16 (permalink) Old 07-13-2014, 11:32 AM
dtmmil's Avatar
i have posted many times about this, if you have a crap map or not sure what you need for af mix you are no better off, just have less money.
i have my wheel at 8 and have timing in most rpm ranges, mine runs good at 8 but in a certain range i do get ping so trying to tune it out.
dyno tune will be best, auto tune is no replacement for a dyno tune.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #7 of 16 (permalink) Old 07-13-2014, 11:34 AM
ndabunka's Avatar
Odd that you would notice THAT much difference as both tunes are pretty much aligned until (what appears to be 3,500RPM). I DO see the increase above that level and can see the benefit of a professional tuner but unless you are cracking it open, most riders would not notice THAT significant of a difference. Did you just not mess with the upper RPMs on the AutoTune much or do you think that the AutoTune itself simply isn't capable of doing those higher RPMs well?
I ask because I am still learning the AutoTune details in an effort to determine it's true value. We KNOW that using an AutoTune is FAR better than without so for a short time, the AT may be something that could help out a LOT of PC-V (without autotune) in the short term... e.g. better than blindly using maps
Ness Thunderheaders
Red Engine Bolts
Madstad System
ndabunka is offline
post #8 of 16 (permalink) Old 07-13-2014, 12:22 PM
Default AFR+ for sure
dobeck's gen IV fuel tuner is so easy, you set the AFR you want + thats it!!! prolly not as "powerful" as a dyno tune done well but very good for me at a lot less $$$$ and headaches. any future upgrades do not need another dyno tune $$$$$
rodhotter is offline
post #9 of 16 (permalink) Old 07-13-2014, 12:33 PM
dtmmil's Avatar
but again , you need to know what af you want.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #10 of 16 (permalink) Old 07-13-2014, 01:12 PM
Default easy setup
install + programming instructions are great. redvic has posted an excellent recommendation + explanation of the setup + how it works. install takes a little time but its not hard. did my own in a few hrs. price is good but even better with a military discount, thanks dobeck!!!
