slime tire pressure valve stem caps - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 07-18-2014, 09:44 AM Thread Starter
dtmmil's Avatar
Default slime tire pressure valve stem caps
anyone use these? i bought some last night , they screw on as a valve stem cap and have a preset psi. if they fall below they go from green to red.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #2 of 19 (permalink) Old 07-18-2014, 10:38 AM
I have never found any for our air pressure.
Where did you find them. They might work pretty good
post #3 of 19 (permalink) Old 07-18-2014, 11:50 AM Thread Starter
dtmmil's Avatar
i got a set of 4 at walmart for. $5 they are for. 36 psi they also have them for 32. with the ct i am running 36-38psi and if it drops below 31 it will change to red , easy enough to glance at pre ride i figured. and as of now i just have it on the rear.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #4 of 19 (permalink) Old 07-18-2014, 01:23 PM
GatorJoe's Avatar
Wish you guys well on this if it loosens up will release the pressure in your tires .. Never again ..
2017 Indian Chieftain Dark Horse/2005 Dyna Super Glide
GatorJoe is offline
post #5 of 19 (permalink) Old 07-18-2014, 01:27 PM Thread Starter
dtmmil's Avatar
have you tried them? this is why i posted, anyone tried them and had troubles? ive seen and heard of the tire pressure monitor setups, how is this different?
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #6 of 19 (permalink) Old 07-18-2014, 01:29 PM
GatorJoe's Avatar
I wouldn't say Never Again if hadn't tried them ..
GatorJoe is offline
post #7 of 19 (permalink) Old 07-18-2014, 01:32 PM Thread Starter
dtmmil's Avatar
well your not really saying much either though. did you try the slime ones or others ? and for those running the monitoring systems how do they work, its a valve cap that screws on right?
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #8 of 19 (permalink) Old 07-18-2014, 01:36 PM
GatorJoe's Avatar
Well your not really saying much either though. did you try the slime ones or others ? and for those running the monitoring systems how do they work, its a valve cap that screws on right?
The Valve Cap Screws on and has to be screwed in tight to get the PSI of the Tire .. What happens with a Tire Gauge if just slightly loose checking the tire? It leaks out air .. The more expensive monitoring system with a seperate source is far more reliable but cost a lot more money as well ..
GatorJoe is offline
post #9 of 19 (permalink) Old 07-18-2014, 01:39 PM Thread Starter
dtmmil's Avatar
yes i see that , the monitoring setups are just a sensor in the cap correct? i can see how they would be more reliable.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #10 of 19 (permalink) Old 07-18-2014, 01:49 PM
GatorJoe's Avatar
No Worries .. Just trying to pass on a bad experience I had with them .. They were fine when the Highway was smooth but when got a back road with lots of bumps and snags all of a sudden realized something was wrong and my rear tire was almost flat .. Good thing carry a portable slime compressor which is no fun doing by yourself on a lonely slanted road ..
GatorJoe is offline
