HELP! 2013 XCT No power being transferred in any gear. - Victory Forums - Victory Motorcycle Forum
post #1 of 45 (permalink) Old 08-28-2014, 08:33 AM Thread Starter
gmaxx's Avatar
Default HELP! 2013 XCT No power being transferred in any gear.
Not sure how to say it, so I'll start with my set up and problems. Please let me know what it is. If it's covered by warranty. If not the general cost of having a local shop fix.
"Vicky" my baby!
2013 XCT
Lloydz high air flow filter.
Ness Big Honkers
PVC
25K miles.
1 year old Aug. 8th 2014
About a month ago maybe a little longer. I started noticing her slipping gears. This then progress to seemly losing her get up and go a highway speeds. Last weekend on a group ride to Atlantic city she had major problems keeping up even with much smaller 900's and the likes. This lost of power has gotten worse. As of today riding into work a 35 miles commute all highway. She completely lost power literally in any gear. She was barely able to maintain 40-50 miles an hour. I ended up putting my flashers on and riding the slow lane or shoulder till I could get off the highway. I barely made into work with her and praying she gets me home so I can get her the help she needs. Please help!
Gmaxx
2013 XCT
Lloydz Air Filter
Ness Big Honkers Pipes
gmaxx is offline
post #2 of 45 (permalink) Old 08-28-2014, 08:42 AM
Motorbikerx's Avatar
"Vicky" my baby!
2013 XCT
Ness Big Honkers
PVC
25K miles.
Slipping gears you say???? Clarify please
At first thought you were describing a slipping clutch but further in your post I get the impression your seriously lacking power.
25k well yr fuel filters due to be changed, I know cos I've just done mine tonight. And it was quite dirty....still flowing fuel ok but.
Itll be intetesting to see how others interpret your problem
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 45 (permalink) Old 08-28-2014, 08:47 AM
LILMAGS500's Avatar
Is the check engine light on ? This could be as simple as a clogged air filter or fuel filter as MBX mentioned .... Is it bucking or missing at all ?
LILMAGS500 is offline
post #4 of 45 (permalink) Old 08-28-2014, 08:49 AM
LILMAGS500's Avatar
Also , make sure your battery terminals are TIGHT and CLEAN !
post #5 of 45 (permalink) Old 08-28-2014, 08:52 AM Thread Starter
gmaxx's Avatar
Let me step back a minute. The engine is running strong. It's just not transferring that power to for lack of better way of saying it to the wheel. When I referred to the slipping of gear early on. I meant there were times when I was in local non highway traffic 1 to 2 to 3 gear I've had her slip into neutral before going to 2 completely.
Gmaxx
2013 XCT
Lloydz Air Filter
gmaxx is offline
post #6 of 45 (permalink) Old 08-28-2014, 08:54 AM
DillPickle311's Avatar
May sound crazy but check your battery voltage. A bad battery could make a perfectly good machine perform this way.
Next, you could definitely be having a fuel flow problem as mentioned... anything from fuel filters to clogged injectors. Good luck!
Check torque on main drive to belt.
DillPickle311 is offline
post #7 of 45 (permalink) Old 08-28-2014, 08:58 AM
So is the engine running normally and not transferring power, or does the motor seem like it has lost power?
post #8 of 45 (permalink) Old 08-28-2014, 09:02 AM
LILMAGS500's Avatar
Sounds to me like you clutch is smoked ... It is probably slipping giving you the feeling of it being in neutral , because it is not holding tight and under a load it is slipping , the engine runs strong but you aren't going anywhere ...
post #9 of 45 (permalink) Old 08-28-2014, 09:03 AM
depot picker's Avatar
Most certainly the clutch is cable is out of adjustment. It should have been addressed promptly.
depot picker is offline
post #10 of 45 (permalink) Old 08-28-2014, 09:22 AM Thread Starter
gmaxx's Avatar
Yes the engine is running strong as heck. I'm just not going anywhere.
Gmaxx
2013 XCT
Lloydz Air Filter
gmaxx is offline
