Oil change - remove transmission drain plug too??? - Victory Forums - Victory Motorcycle Forum
 1Likes
post #1 of 14 (permalink) Old 08-29-2014, 10:15 AM Thread Starter
ChopperJeff's Avatar
Default Oil change - remove transmission drain plug too???
Just purchased the Victory Oil kit and changed the oil last night on my 2014 Jackpot. I noticed that along with the washer for the oil drain plug there were two other bags containing O-rings. A Google search revealed they are the O-rings for the transmission drain plug. Here's the site that shows it:
http://www.2wheelpros.com/oem-parts/...2020-part.html
Being that the kit provides these washers, are you suppose to remove that drain plug too when doing the oil? The owners manual only says to remove the oil drain plug, and of course the filter. No mention is made of the transmission drain plug.
So, WTF?
ChopperJeff is offline
post #2 of 14 (permalink) Old 08-29-2014, 10:19 AM
TNXR's Avatar
Dude, there is no "transmission" drain plug. Vics are like Jap bikes where the oil is for the engine and tranny. My oil change kit came with an O-ring for the oil dipstick and a couple of different washers based on if you got the 100 or 106 engine.
2011 Cross Roads Sunset Red
TNXR is offline
post #3 of 14 (permalink) Old 08-29-2014, 10:27 AM Thread Starter
Yes, I thought it strange that the OEM site mentions a transmission drain plug as I knew that the tranny was basically part of the engine. However, I figured too that it wouldn't mean they couldn't have a drain plug located in that area of the motor. Just noticed that the OEM site I looked at says "2001 Victory DELUXE CRUISER (V01CD15CC)". So perhaps the older Victories had this other drain plug? Figured Victory must have included these O-rings for a reason.
post #4 of 14 (permalink) Old 08-29-2014, 11:30 AM
The oil kit is for other Polaris models.
You want the copper washer for your drain plug and the rest of the stuff throw in a drawer
post #5 of 14 (permalink) Old 08-29-2014, 01:07 PM
do yourself + your bike a favor next change, put in Amsoil from our sponsor at a similar cost. a modern V-twin as our Vics deserve modern REAL synthetic oil!!!
rodhotter is offline
post #6 of 14 (permalink) Old 08-29-2014, 02:31 PM
vindex1963's Avatar
My X-wife had REAL modern synthetic breasts and they also sucked the $$$ out of my pocket.
Y62 likes this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #7 of 14 (permalink) Old 08-29-2014, 03:49 PM
Weeds's Avatar
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #8 of 14 (permalink) Old 08-29-2014, 04:03 PM
8BallHammer's Avatar
Don't be a jack-ass to him, when I first bought my 2 stroke Lawn-Boy I spent quite a bit of time looking for the drainplug so that I could change the oil after breaking it in.
When I couldn't find it, I went to the dealer where I bought it looking for an oil change kit and to ask where the drainplug was
2013 AF Green Crossed Country
TriOval slip ons
Lloydz VM-1 DR Cams
Lloydz PTS +4 degrees
PC V
Lloydz air filter
1/4 turn throttle
99.7 HP/107.2TQ
Now you know how I've felt for the last 8 years:D
8BallHammer is offline
post #9 of 14 (permalink) Old 08-29-2014, 04:38 PM
Goatlocker95's Avatar
What part of TNXR's post do you think he was being a jack-ass???
He simply told him there isn't a transmission o-ring and the reason why there are more parts in the box than what he needs. Nothing "jack-assed" about that.
2014 Indian Chieftain
Goatlocker95 is offline
post #10 of 14 (permalink) Old 08-29-2014, 05:56 PM
don't use any synthetic oil till your motor is broke in. Your valves and rings and other parts have to seat in first.
