X Bike slip-ons swap, PCV tune? - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 08-31-2014, 02:46 PM Thread Starter
bsbabcock's Avatar
Default X Bike slip-ons swap, PCV tune?
So I'm running a beautifully awesome PCV map tuned by Kyle for my Tri-Ovals, cams, +4 wheel and filter.
I'm considering sending the stock mufflers for a Big Gonzo mod. Probably more free flowing top end than the Tri's. I wonder how bad it'd be off on the map if I swapped, or if it could be tweaked to run pretty darn close until I can dyno tune it perfect?
Any experiences and knowledge with that?
2013 Hard-Ball - Lloydz VM1-DR cams, air filter, timing wheel, PCV, properly tuned at KMC
Master, Biltmore Lodge #446, AF&AM
bsbabcock is offline
post #2 of 7 (permalink) Old 08-31-2014, 03:39 PM
I'd stick with what you have. Rylan Vos, one of the top Vic mech's speaks highly of the Tri-Ovals. It's also what KevinX runs; another top notch Vic mech.
What's a Gonzo mod? It sounds like your bike would need to be re-dyno'd.
post #3 of 7 (permalink) Old 08-31-2014, 05:32 PM
Rebel Biker's Avatar
I agree with Bbob. I'd stick with what you have. I'd bet your tri-ovals will put down better numbers than them gonzo things. I've actually not seen a dyno sheet better than tri-ovals. If its just sound you're after, sounds like some expensive noise. Changing back pressure, flow etc will certainly necessitate another tune.
https://www.youtube.com/watch?v=KOZw...ature=youtu.be
2014 Victory Cross Country Tour - Two Tone Sonic Blue and Silver
PCV 6,500 rev limit, Lloydz VM1-DR Cams, Lloydz Hi Flow Filter, Atom Bomb exhaust, Lloydz ATS +4, Lloydz 1/4 Throttle. 111 HP / 116 TQ
2012 Victory Kingpin - Traded in on XCT
2007 Honda Shadow Aero 750 - Traded in on KP
Rebel Biker is offline
post #4 of 7 (permalink) Old 09-01-2014, 02:01 PM Thread Starter
bsbabcock's Avatar
http://youtu.be/Wk5fneDefhI
Basically a re-cored muffler similar to Nascar6 or Thrush, Witchdoctors, etc etc. I believe the Big Gonzo is an open core with a flanged tuned large end port. Sound great. Kyle and Lloyd had nice comments on them in Helen at the rally and they tested well.
post #5 of 7 (permalink) Old 09-01-2014, 02:24 PM
check out the return policy before getting those. Not to mention a youtube clip is probably not a great representative of how they really sound.
14 hava. red xc
2013 Vegas 8-ball
pc5 w/at, bassani pro-street turnouts, intake, lloydz super wheel +6
2004 Vtx-1300c *retired and sold*
lykoi626 is offline
post #6 of 7 (permalink) Old 09-01-2014, 04:49 PM Thread Starter
bsbabcock's Avatar
True I'll look into that. So far I'm going a couple local friends that love em. I'll continue to research them.
post #7 of 7 (permalink) Old 09-01-2014, 08:35 PM
dtmmil's Avatar
if you have someone close with the gonzos , see if you can swap to try them out, wouldnt take long to figure out if your tune will work or not
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
