RPM/Throttle question - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 08-31-2014, 06:30 PM Thread Starter
Question RPM/Throttle question
I recently took an advanced motorcycle safety course (the military requires us to do this now) and while I was in the course we had to navigate around cones keeping the throttle at a constant rpm. What I noticed was that the bike could not maintain it, it seemed like it wanted to shut off on me. The RPMs would dip to 850 and then level back off. While playing with the throttle during the course if I would bring the throttle forward just a little bit the bike would jolt forward (like if I had released the throttle all at once). What could be causing this? does there need to be a throttle adjustment? does it need to run richer? any pointers would be great
new-vic-owner is offline
post #2 of 10 (permalink) Old 08-31-2014, 07:03 PM
Tims_04V92TC's Avatar
Year and model bike?
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #3 of 10 (permalink) Old 08-31-2014, 07:17 PM Thread Starter
Sorry thought I had updated my account...Vegas 8-ball 2012
post #4 of 10 (permalink) Old 08-31-2014, 07:38 PM
Travis P's Avatar
It is the nature of the Vic engine... Advance timing wheel and idle air valve is supposed to help. I have 1/4 throttle and ATS from lloydz and I no longer have that issue. I say 1/4 throttle only because I installed both at the same time so not sure which fixed the issue.
Travis P is offline
post #5 of 10 (permalink) Old 08-31-2014, 09:51 PM
Motorbikerx's Avatar
yeah they can be a little inconsistent down low in stock tune.
Timing wheel and IAV may clean it up a bit, but the open road beats traffic cones anyday.
Maybe do the cones on a different bike?....there's a lot of weight in limbo if these things stall out while turning slow...hard to defy gravity whilst stationary.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 10 (permalink) Old 09-01-2014, 08:23 AM
bdbaggr's Avatar
i will agree with travis that the 1/4 turn throttle ring helped take the slop out of the cable, also the nature of the motor in stock form doesnt like the low rpm rolling state, i had problems coming off of h-d in the beginning, but after ats, cams, filters, pipe, throttle ring and practice its decent down low now, still not like a h-d at that rpm, but decent...
bdbaggr is offline
post #7 of 10 (permalink) Old 09-01-2014, 08:42 AM
Lostintexas's Avatar
Where were you trying to hold the RPM's and were you popping it up to them? Mine doesn't seem to have the problem and if it did I blamed it on myself. Doesn't mean something int happening though.
I always went by engine sound and after coming off a boxer 6, to a twin, there is about as much difference as it gets. Been riding the bike for long?
I agree a tuner and air filter will cure some ills, but too much unknown about your situation. Practice, practice and practice. Sounds like this was a new drill for you or you on the bike anyway.
Kind of hard to really figure some of the subtle things out over the internet.
Cheers and Semper Fi
I ride with the Force.
Lostintexas is offline
post #8 of 10 (permalink) Old 09-01-2014, 09:08 AM
Tarzan's Avatar
Slow speed maneuvering is easier for me to control by keeping the rpm's up and slipping the clutch while using the back brake. Maybe you are too low in the rpm range?
'14 Ness XC
Tarzan is offline
post #9 of 10 (permalink) Old 09-01-2014, 09:49 AM
Same advice here when I do the parking lot maneuvers with my gold wing buddies. A couple quests is how warm was the bike and when you say dip it dipped from what RPm? Maybe a lil too much play in the cables but it almost sounds like the IAV for the most part. I do have the 1/4 ring and ATS on my vision and if I stay at low rpms before the engine gets good and warm the IAV will give it that dip every once in a while then recover. Do what Tarzan does above and I have no issues cold or not hence why I have yet to spend the 80 bucks on the IAV.
Post some feedback if you experiment.
Safe ridin. Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
post #10 of 10 (permalink) Old 09-01-2014, 10:46 AM
Its your Idle Air Valve that is causing the problem. Vic uses a vacuum one and it sucks the only thing you can do is change it for Lloydz IAV witch is adjustable. Am guessing you were blipping the throttle while doing the ride and Vic motors don't like blipping.
Timing wheel and 1/4 turn are good parts but will only change your hesitation by a very little bit
http://www.lloydz.com/store/item_vie...itemid=1000078
