Conquest Customs Ground Pounders Review - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 03-17-2012, 01:32 PM Thread Starter
domjaun's Avatar
Default Conquest Customs Ground Pounders Review
Hello all,
Finally got the new pipes on and the finned covers. They look great and sound awesome. You cant even begin to imagine how these sound unless you here them in person, recordings do not do it justice at all. To compare them to any other exhaust I have heard or felt for that matter, nothing even comes close. These are called ground pounders for a reason you will know why if you here them in person. Had a small exhaust leak at first but it was my fault, its fixed now. I will be taking it to get tuned and put on the dyno Tuesday and I will post the graph then. For those who don't buy these because you think you need the new oil cooler, you don't. I was able to move mine enough to clear the front pipe. I just had to make a different bracket to mount the cooler, in the existing mounting holes. It does not look as good as if I were to get the other oil cooler but it does work. Maybe I will upgrade later, but for now it works fine. Throttle response is better and it seems to run smoother. I also do not have the annoying exhaust pop anymore.
I have some pics to upload but I am having some issues attaching them. Any help would be great. Thanks.
2009 Jackpot
Power Commander V
Lloydz Air Cleaner
Conquest Customs Ground Pounders Exhaust
Hammer V Bars
Finned Open Final Drive Cover
Finned Derby and Primary Cover
Custom Made LED Rear Turn Signals
Wrap Around Front Turn Signals
Side Mount Plate
domjaun is offline
post #2 of 3 (permalink) Old 04-16-2015, 09:58 AM
I know it's been some time since you posted this, but I am interested in getting them too on my Vegas. Were you ever able to post any photos? I would also like to know how you re-mounted the oil cooler and if this is something I will be able to do. I.e. what parts are needed?
Many thanks!!
ukflyer is offline
post #3 of 3 (permalink) Old 04-19-2015, 07:41 PM
Brasmi's Avatar
I'm also curious about the dyno numbers with Ground Pounders. I just had my High-Ball dyno'd with Hacker Zoomies and would like to compare.
2014 Victory High-Ball
Hacker Zoomies Exhaust; Lloydz HOH-VM1-HP-DR Performance Cams; Lloydz Torque Tubes; Power Commander V; Lloydz Adjustable Timing Wheel (+5); Kuryakyn Skeleton Hand Mirrors; Kuryakyn ISO Grips; Franklin Ames Black Powder-Coat Dipstick; Witchdoctors Sissybar and Luggage Rack; White Wall Choppers 1.5" lower kit.
99.3 HP, 114.4 FT-LB torque (before cams installed - waiting on new dyno for increased numbers).
Brasmi is offline
