Clutch Cable diameter? - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 09-19-2014, 09:32 AM Thread Starter
archaicguy's Avatar
Default Clutch Cable diameter?
Can someone give me a measurement on the diameter of the clutch cable please? Just the inner cable so I can slide the new cable through the stock sleeving like the Sav-UR-Ride Clutch Repair Cable.
Mine broke on me yesterday and I managed to limp my girl home.
I work for an aerospace manufacturer and have access to all sorts of steel braided cables, bare and plasic coated so I figure I could save myself plenty of money by only needing to purchase cable stop clamps.
I figure the cable I can get is every bit as good if not better than what I can get as a stock replacement, a couple stops and an additional crimp clamp or 2 on the ends and for about 8 dollars I'm back in business.
Thanks
2016 Cross Country
1969 Firebird
1979 10th Ann. Trans Am
1979 Solar Gold Trans Am
2010 Challenger R/T - Plum Crazy Purple
archaicguy is offline
post #2 of 13 (permalink) Old 09-19-2014, 09:42 AM
Pauljp's Avatar
The bare cable on my 2014 CCT measures 2.5mm (0.098")
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #3 of 13 (permalink) Old 09-19-2014, 10:10 AM
archaicguy
Show us what you come up with please
post #4 of 13 (permalink) Old 09-19-2014, 10:12 AM Thread Starter
archaicguy's Avatar
Awesome.... sure figured I could get a response by the end of the work day. Got plenty of that size cable in stock. Thanks
I will post what I end up with for sure.
2016 Cross Country
1969 Firebird
post #5 of 13 (permalink) Old 09-19-2014, 10:13 AM
Motorbikerx's Avatar
Could be a market for em
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 13 (permalink) Old 09-22-2014, 10:16 AM Thread Starter
archaicguy's Avatar
Ok problem fixed temporarily while I work up my design for a permanent fix, this setup should last a long time though and I will take it apart and check wear on it in a couple weeks.
Cable stops from autozone $3
Bolts from home depot $3
My total cost is $6 since I can use supplies from my work.
Here are some pics of the products and how I set it up.
The steel cable goes through the stop and is fastened down by the bolt and also added crimp sleeves to prevent and monitor any slippage of the cable and covered it with heat shrink tubing. More permanent and cleaner cable setup to come.
2016 Cross Country
1969 Firebird
post #7 of 13 (permalink) Old 09-22-2014, 12:50 PM
Drastik's Avatar
Good use of available resources! I'd like to see the new 'permanent' setup as well, when you have it done.
Semper Fidelis!
04 Vegas
Drastik is offline
post #8 of 13 (permalink) Old 09-22-2014, 06:06 PM
If you could put a eyelet like this cable it would never break at the clutch lever
post #9 of 13 (permalink) Old 09-23-2014, 02:36 AM
yeah me too and Id probably be up for buying one myself
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #10 of 13 (permalink) Old 09-23-2014, 02:55 AM
Tech23's Avatar
If the ends prove more reliable than the stock cable I bet the cable itself lasts a long time. It appears to be braided bundles of wire, unlike the usual plain braided cable. I wonder if being a more coarse braid will increase drag and lever effort.
Tech23
Tech23 is offline
