Electric help, what is this plug? - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 09-23-2014, 06:21 PM Thread Starter
Dustin0479's Avatar
Default Electric help, what is this plug?
Looking for a ignition controlled power source that will support a 12a compressor. Anyone recognize this plug? ImageUploadedByMotorcycle1411514483.634017.jpg
Sent from Motorcycle.com App
Dustin0479 is offline
post #2 of 9 (permalink) Old 09-23-2014, 06:38 PM
That's for the heated seat
vcc14 is offline
post #3 of 9 (permalink) Old 09-23-2014, 07:04 PM Thread Starter
Dustin0479's Avatar
Anyone have the specs for the heated seat? How many amps? Does it have a fuse onboard?
post #4 of 9 (permalink) Old 09-24-2014, 02:57 PM
BenD's Avatar
[QUOTE=Dustin0479;1136682]Anyone have the specs for the heated seat? How many amps? Does it have a fuse onboard?
There is a 20 amp fuse located between the 40 amp breaker and the chassis relay, which feeds the seat.
2012 XC Tour, Sunset Red/Silver, California Sidecar Trike Conversion, custom seat by CycleOpsUSA.com
Phoenix, AZ
BenD is offline
post #5 of 9 (permalink) Old 09-24-2014, 05:16 PM
Dustin0479
I thought you were the type that would read your owners book and see the information. Guess not
post #6 of 9 (permalink) Old 09-24-2014, 06:32 PM Thread Starter
Dustin0479's Avatar
I have the manual but could not for the life of me find it anywhere in there last night. The mechanical side of the manual is killer, the wiring portions suck!
post #7 of 9 (permalink) Old 09-24-2014, 06:33 PM Thread Starter
Dustin0479's Avatar
[quote=BenD;1138426]
Awesome, thank you!
post #8 of 9 (permalink) Old 09-24-2014, 06:49 PM
Lostintexas's Avatar
The 20A fuse is labeled chassis in the fuse box IIRC. This same fuse will not let the cruise set if blown. It probably has some more functions as well, just not sure what. My seat kept blowing the fuse and I knew it was gone after the cruise cut. It will turn on, red light on the control, but not set. Confusing.
Vic must have done the electrical on a hangover Monday after a 2 week rally and a 96 hour ride back home.
I ride with the Force.
Lostintexas is offline
post #9 of 9 (permalink) Old 09-24-2014, 07:22 PM Thread Starter
Dustin0479's Avatar
Thanks. I am going to drop a 15 amp fuse on a line I jump off there for the air ride. Working on fabricating some brackets and getting ready to do an install video for a Platinum Air ride on the xc.
