1/4 throttle instalation need help - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 09-23-2014, 10:33 PM Thread Starter
Default 1/4 throttle instalation need help
I am trying to install the 1/4 throttle ring on a 2014 xct and i am doing something wrong but i do not have enough cable to finish the instalation. I have watched witchdoctors' video and i compleated the following steps:
1.- I have lossen the nuts (left side of the bracket) of both cables at the throttle body to get some slack
2.- I have lossen the cable micro adjusters on the handlebar all the way to get the maximum cable slack
3.- I have opened the switch casing, installed the 1/4 ring (the grips are the heated stock ones)
4.- Connected the back cable over the ring, no problem
5.- Then tried to connect the front cable over the ring to it's housing and that is when my problems started, i do not have enough cable to drive it in its housing.
Please advise what i have done wrong or missing
2014 XCT, Utopia Backrest, Guard Dawg, Longhorn brake pedal, ISO Longhorn shifter, Arlen Ness gas cap, VM-1 Cams, Lloydz ATS, Lloydz air filter, PCV, Madstad Windshield, Victory HID, Vance & Hines Hi-output. 118/120 Dyno tuned by Kyle.
Jlvazquez6 is offline
post #2 of 11 (permalink) Old 09-24-2014, 12:04 AM
Rebel Biker's Avatar
There is nothing abnormal going on. It's a tight fit even after giving it all the slack there is. I've done this 3 times, twice on the KP (stock grips then heated) and the other on the CCT. Each time after I get all the slack I can, I pull the end up to the hole just enough to hold it then I take a small angled pick and grab the cable and pull it over into the slot while pressing on the end. Once it's in the slot, it'll be loose and you'll tighten up your cables.
https://www.youtube.com/watch?v=KOZw...ature=youtu.be
2014 Victory Cross Country Tour - Two Tone Sonic Blue and Silver
PCV 6,500 rev limit, Lloydz VM1-DR Cams, Lloydz Hi Flow Filter, Atom Bomb exhaust, Lloydz ATS +4, Lloydz 1/4 Throttle. 111 HP / 116 TQ
2012 Victory Kingpin - Traded in on XCT
2007 Honda Shadow Aero 750 - Traded in on KP
Rebel Biker is offline
post #3 of 11 (permalink) Old 09-24-2014, 03:58 AM
LILMAGS500's Avatar
Make sure you screwed these in and not out .....
LILMAGS500 is offline
post #4 of 11 (permalink) Old 09-24-2014, 07:05 AM Thread Starter
Thanks for the reply it is very tight and i do not know if i am going to be able to drive it into its place, but i will try tonight
post #5 of 11 (permalink) Old 09-24-2014, 07:06 AM Thread Starter
Thanks for the reply, yes i did all the way in
post #6 of 11 (permalink) Old 09-24-2014, 10:29 AM
Do you have the HR-1 1/4 turn. If not you have the wrong one
post #7 of 11 (permalink) Old 09-24-2014, 11:39 AM Thread Starter
Yes I got the HR-1, it fits perfectly around the grip the problem is that I do not have enough slack on the cable to install it. I am going to follow RB advise tonight and see if I can do it, if not I am going to swallow the ring LOL
post #8 of 11 (permalink) Old 09-24-2014, 12:18 PM
LILMAGS500's Avatar
If you cant get it to work you are doing something incorrectly , you would be the first ....
post #9 of 11 (permalink) Old 09-24-2014, 12:40 PM
depot picker's Avatar
You'll pay Hell tying to pass it.
depot picker is offline
post #10 of 11 (permalink) Old 09-24-2014, 01:06 PM
LILMAGS500's Avatar
Good luck just getting it down !
