Neutral light everytime I shift - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 09-28-2014, 01:16 PM Thread Starter
Tenac's Avatar
Default Neutral light everytime I shift
Has anyone had the Neutral light show up every time you pull in the clutch??? Does anyone have any idea what might be causing this?
So far I have tried checking connections all look good.
Clutch adjustment in a great spot and shifts smooth.
So as long as I hold in the clutch the neutral light stays on... Bike has been sitting for a couple weeks while I was on a trip for work came back to a bad starter solenoid which I knew was going out so replaced that and everything is good on that end just that darn neutral light.
2008 Hammer
LED
2 into 1 No baffle
Lloydz intake
Power Commander 3
CHROME
Speakers
Tenac is offline
post #2 of 18 (permalink) Old 09-29-2014, 10:39 AM
bnhender's Avatar
Slightly off topic, but what were your clues that your starter solenoid was failing?
___________________________________
Bill
2012 Cross Roads (Sunset Red)
Stage 1 flash
Lloydz Air Filter
Lloydz Idle Control Valve
Lloydz Adjustable Timing Wheel
Freedom Performance True-Dual Exhaust
VM1-DR cams
O2 Sensors disconnected
21" Adrenaline Front Wheel
Cee Bailey 24" windscreen w/ lowers
Tachometer
Small Bullet Light Bar
LED Headlight
Grasshopper driver backrest
Victory passenger backrest
Chrome saddlebag rails
2017 Octane
Shorty pipes
Navasota, TX
bnhender is offline
post #3 of 18 (permalink) Old 09-29-2014, 11:34 AM Thread Starter
Tenac's Avatar
When I press the start button you can hear the COIL attempting to pull in and stay but it rattles. After checking the connections I deemed it was bad. Replaced it and now starts up fast just like new.
2008 Hammer
LED
2 into 1 No baffle
Lloydz intake
Power Commander 3
CHROME
Speakers
Tenac is offline
post #4 of 18 (permalink) Old 09-29-2014, 11:43 AM
bnhender's Avatar
Thanks.
I have noticed that occasionally I will push the starter button and get nothing. Push it again and it fires up. Been playing with it to see if it matters "how" I push it (pressure down, up, on tip, etc.) as I am assuming I have a switch that is not contacting all the time. Can't seem to get a consistent way that causes it not to connect.
Looked inside the housing and can't tell if I can replace JUST the switch or if I need to replace the whole housing.
Bill
Stage 1 flash
Lloydz Air Filter
VM1-DR cams
Tachometer
LED Headlight
2017 Octane
Shorty pipes
Navasota, TX
bnhender is offline
post #5 of 18 (permalink) Old 09-29-2014, 12:08 PM Thread Starter
Tenac's Avatar
Thanks.
I would start with the solenoid its 14 bucks on amazon. Also what you are describing was an issues i was seeing as well. Your switch is probably fine. Also check the starter connections. I have found them loose before.
2008 Hammer
LED
2 into 1 No baffle
Lloydz intake
Power Commander 3
CHROME
Speakers
Tenac is offline
post #6 of 18 (permalink) Old 09-29-2014, 03:33 PM
I would think that it could be a grounding issue.
It would seem they are unrelated systems so the one thing they would have in common is they both use a ground.
Does the neutral light work right in neutral?
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #7 of 18 (permalink) Old 09-29-2014, 03:40 PM Thread Starter
Tenac's Avatar
Yes it works just fine in neutral. You might be on to something with grounding issues... It only happens to light when clutch is pulled in. I might start by disconnecting that switch at the clutch.
2008 Hammer
LED
2 into 1 No baffle
Lloydz intake
Power Commander 3
CHROME
Speakers
Tenac is offline
post #8 of 18 (permalink) Old 09-29-2014, 04:00 PM
Post your results please. I am interested in the outcome
Rootzee is offline
post #9 of 18 (permalink) Old 09-29-2014, 04:29 PM
Here is another thought.
Make up a long jumper cable 5 ft long with a pair of alligator clips on it.
Try to get the ones that are able to open up quite far, something like this works really good.
But if those aren't handy anything will work. The wire can be almost anything 16 gauge is fine.
Pull your battery cover and hook right to the negative terminal of the battery and go to anything that you are in doubt is grounded.
Since the neutral indicator switch is on the engine go to a good clean bolt in the engine and see if your problem disappears.
Most aluminum is clear powder coated for corrosion protection so you will have to remove the powder coat to get a bare spot. Unlike a bolt that generally is plated and conducts electricity.
You can move it around to other places like the instrument display grounding terminal and see if that helps.
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #10 of 18 (permalink) Old 09-29-2014, 07:52 PM Thread Starter
Tenac's Avatar
Okay so unplugging the clutch switch solved my issue no more neutral light when I'm shifting.
2008 Hammer
LED
2 into 1 No baffle
Lloydz intake
Power Commander 3
CHROME
Speakers
Tenac is offline
