Engine knock - Victory Forums - Victory Motorcycle Forum
post #1 of 23 (permalink) Old 09-30-2014, 05:20 PM Thread Starter
Default Engine knock
Ok out of all the riders on here has anyone one had a blown engine or had there 106 develop a knock in the motor ? Stay tuned for the culprit. Going to see Rylan in a trailer thats sad !
My ride
2013 Vision Touring. Shelbyville IL
Lloyds 116 big bore
Lloyds timing wheel set at plus 2
Lloyds adjustble intake
Lloyds HP cams
Lloyds quarter turn throttle
PCV 5
Ness Big Honkers
Lloyds Vision intake plate
Lloyds variable clutch
Heads worked over
Built and tuned by Rylan Vos at The Vic Shop
Adel ia.
136HP 139FTLBS
new vic rider is offline
post #2 of 23 (permalink) Old 09-30-2014, 06:05 PM
What have you done since Rylan tuned it?
Maybe PCV is not working right
post #3 of 23 (permalink) Old 09-30-2014, 06:07 PM
Wetland Destroyer's Avatar
I am planning on going down to see Rylan this spring so im interested to see what happend I know he has done alot of bikes with no problems.
2014 Cross country
Lloydz HOH-VM1-HPT-DR Cams, PC-V, , timing wheel, Lloydz air cleaner ,1/4 turn throttle and D&D unwrapped pipes Tuned to 123.97/115.94 By Rylan Vos at The Vic Shop.
Wetland Destroyer is offline
post #4 of 23 (permalink) Old 09-30-2014, 07:11 PM
Pheonix's Avatar
I doubt VERY seriously that ANYTHING Rylan did caused any problems. What we seem to forget, from time to time, is that although reliable.... Vics have a mechanical motor. ALL things mechanical are subject to fail. It happens, ALTHOUGH RARE with Vics.......
2011 Kingpin - Scarlett
Stage I Pipes with Thunder Monsters & NO Catcons
Ness Laydown Plate Holder with Custom Dynamics LED Plate Frame
Custom Ness Engine Covers
V92C Floorboards with NON-LOW Mounts
Ness Ram-Air
PC-V
Lloydz Timing Wheel
Dyno Tuned by 804 Motor Sports
97.26 HP / 110.42 # for now...
Pheonix is offline
post #5 of 23 (permalink) Old 09-30-2014, 08:04 PM
Oldman47's Avatar
How about a hint of what is wrong. Are you getting a ping or do you have some kind of mechanical malfunction causing noise? Have you done any investigation or basic troubleshooting, like checking the timing wheel to see if it has moved?
Oldman47 is offline
post #6 of 23 (permalink) Old 09-30-2014, 08:30 PM Thread Starter
Checked timing wheel all good. I was not saying it was Rylans fault at all ! I will repeat it is not Rylans fault. Where did I say it was Rylans fault ? It is a mechanical knock. If it needs rebuilt it will get the 116. I trust Rylan thats why I am loading it in the trailer and taking it 420 miles instead of 30 miles to my dealer. He will fix it cuz he knows his shit !
My ride
Lloyds 116 big bore
Lloyds HP cams
PCV 5
Ness Big Honkers
Heads worked over
Adel ia.
136HP 139FTLBS
post #7 of 23 (permalink) Old 09-30-2014, 08:36 PM
Oldman47's Avatar
Nobody said it was Rylan's fault. Just curious what you have done to narrow it down.
Oldman47 is offline
post #8 of 23 (permalink) Old 09-30-2014, 08:57 PM Thread Starter
Change the oil every 3000 miles is all I have done.
My ride
Lloyds 116 big bore
Lloyds HP cams
PCV 5
Ness Big Honkers
Heads worked over
Adel ia.
136HP 139FTLBS
post #9 of 23 (permalink) Old 09-30-2014, 09:22 PM
beast30's Avatar
When is the knock occuring? Certain rpm? At idle? All the time? Very curious to see what Rylan and Gabe find.
2012 XC Imperial Blue/Blacked out, LLoyds filter, LLoyds timing wheel,
VM1 DR cams, PC5, LLoyds ECM, Big Gonzo, KM meat hook bars (internally wired), Conquest underdrive pulley, KM instrument bezels, JTD lowers with speakers, PBR300 amp with Polk 6.5, .40 cal cheese wedges, tinted turn and tail
beast30 is offline
post #10 of 23 (permalink) Old 09-30-2014, 09:25 PM Thread Starter
Pretty much there all the time. More on decel and idle though.
My ride
Lloyds 116 big bore
Lloyds HP cams
PCV 5
Ness Big Honkers
Heads worked over
Adel ia.
136HP 139FTLBS
