Oil report Rotella T 15W/40 - Victory Forums - Victory Motorcycle Forum
 18Likes
post #1 of 178 (permalink) Old 04-04-2012, 05:56 PM Thread Starter
vindex1963's Avatar
Default Oil report Rotella T 15W/40
This is based on Victory recommending a 2500 mile oil change for my year and model.
As you can see I can and will go much longer next time. I'll send in the next sample at 5000 miles.
Rotella T is just a little over $3.00 a qt. and tested great!!!
I used the factory filter.
I'm continuing this thread.
Tech23 likes this.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #2 of 178 (permalink) Old 04-04-2012, 06:07 PM
I had a feeling they were being overly cautious with the 2500 mile oil change recommendation.
Thanks for posting this!
Tech23 likes this.
post #3 of 178 (permalink) Old 04-04-2012, 06:10 PM
Good to know. Thanks.
2010 XC Midnight Cherry
cams/D&D
2009 Ness Vision
116 Big Bore
"The Millinium Falcon"
Blueline is offline
post #4 of 178 (permalink) Old 04-04-2012, 06:14 PM Thread Starter
vindex1963's Avatar
You're both welcome. Good to know. Now we'll see what it looks like at 5000 or twice the recommended drain interval. That cuts the just over $3.00 a qt to just over $1.50 if 5000 is good.
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #5 of 178 (permalink) Old 04-04-2012, 08:04 PM
I'm using the Rotella T6 5W-40. I wonder how that translates? Any thoughts? I'll be sending a sample in too.
post #6 of 178 (permalink) Old 04-04-2012, 08:08 PM Thread Starter
vindex1963's Avatar
Being a full synthetic your sample should be better than mine.
How many miles are you going to change it out at?
Tank riser
VM-1 DR cams
Timing wheel +4
PC-V 118hp 116tq
post #7 of 178 (permalink) Old 04-04-2012, 08:13 PM
A lot of Goldwing owners also use Rotella 15-40 and change it around 5000 miles.o problems have been reported.
dr d is offline
post #8 of 178 (permalink) Old 04-04-2012, 08:17 PM
I was thinking along the lines of a 2500 mile change due to that being about 3/4 of a year with some long layovers during cold and rainy weather. After viewing your results, I'm rethinking that to much farther down the road.
post #9 of 178 (permalink) Old 04-05-2012, 09:25 AM
handyhoward's Avatar
I have used Rotella T6 along with the Fram filter for many different bikes including my Vision and find it to work quite well... I change it every 10,000 miles whether it needs it or not. I travel roughly 30,000 miles a year.
I-8-BALL likes this.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #10 of 178 (permalink) Old 04-05-2012, 12:01 PM
You might want to consider a higher quality filter. Search the oil/filter threads for info. Fram will stop large moths and small birds but nothing smaller.
