Cruise control not working. - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 04-07-2012, 07:21 PM Thread Starter
Default Cruise control not working.
HELP!
I have the Victory cruise control kit installed on my Vegas 8-ball. It was bought in the USA and installed by my local dealer, here in the UK, late last year. They said they had never installed one before. The throttle cable was missing from the kit, so I had to get another one shipped from the USA. The bike was in their workshop for weeks.
So the weather closed in for the winter right after I got the bike back, so no long runs. Today was the first day I had a chance to try it out and guess what? It doesn't work!! The on light comes on, but when I press SET it does nothing to hold the speed. I tried tapping it as well as holding it for 10 seconds... nothing. I tried 20, 40 and 50 MPH, still nothing.
Is there anything I can check as to why this would be? I feel like an idiot going back to the dealer to ask them to check it, especially 5 months after they did the work. They did tell me they tested it when they installed it.
I believe this is the only accessory install of a cruise control in the UK. Victory UK have never once sold one.
I have a 2010 UK spec model, which is like the US 2011 model. I.e. 106 CI and 6 speed tranny.
Thanks guys.
ukflyer is offline
post #2 of 13 (permalink) Old 04-07-2012, 07:27 PM
CrossRoads's Avatar
Originally Posted by ukflyer View Post
HELP!
Thanks guys.
Sorry to hear (read) about your misfortune. Don't feel too bad. Mine was factory installed and did not work since day one. The first thing to check is your switches (clutch and brakes) - see service manual for procedure on testing.
It turned out to be a faulty front brake switch for me.
CrossRoads is offline
post #3 of 13 (permalink) Old 04-07-2012, 08:34 PM Thread Starter
Hi Crossroads,
Thanks for the reply. Where/how can I get to see the service manual?
Did you get your cruise control sorted?
Thanks again!
James.
ukflyer is offline
post #4 of 13 (permalink) Old 04-08-2012, 03:53 AM
gibson's Avatar
If the accessory cruise control will not set or will not remain set and a throttle safety switch is suspected, perform the following test. The throttle safety switch sends a power to the cruise control module to cancel a cruise setting when the throttle is closed. Power should not be present on pin D at the module connecter unless the throttle is closed.
1. Disconnect doth wires from switch on throttle closing cable.
2. connect an ohmmeter to switch terminals. Switch should be open(OL).
3. Close throttle grip firmly. Switch should have a good continuity (less than 1 Ohm resistance).
4. Turn key on. Verify battery voltage is present on the lt BU/PK wire.
5. Re-connect switch wires securely to terminals.
Found on page 19.19 of the manual. To test all brake, clutch switches for no opens if this does not check out..
2012 Fireball Jackpot
gibson is offline
post #5 of 13 (permalink) Old 04-08-2012, 08:06 AM
handyhoward's Avatar
Pull apart all of the connections and the hoses to the system... blow dry with a hair dryer... don't get them too hot... add dielectric grease to all connections including the hoses. These cruise control systems are dampness sensitive and fail often after a rain, a sweat, or a bath.
PS... be sure to mark the connections and hoses before you pull them apart.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #6 of 13 (permalink) Old 04-08-2012, 08:10 AM
depot picker's Avatar
If your brake lights are modified it can cause CC not to work too.
depot picker is offline
post #7 of 13 (permalink) Old 04-08-2012, 08:00 PM Thread Starter
Thanks Guys,
Brake lights are stock.
Dielectric grease not easy to find here. I think I can use vaseline; at least according to this http://hardwarespot.co.uk/review-pag...ectric-grease/ site.
Can you please tell me how many connections/hoses there are and their locations? As I had the dealer install this, I have no idea.
Thanks,
James.
ukflyer is offline
post #8 of 13 (permalink) Old 04-09-2012, 07:58 AM
gibson's Avatar
If you do not know how, I would let the dealer that installed it fix it. There is a list of switches in series that have to be made, plus wiring harness connections. Without a book with color coded wire diagram, you could seriously screw it up where other things could go wrong. If you do not know electrical I would highly recommend taking it back to the dealer. surely they will not charge you for something that does not work that they have installed. To try to tell you how with little to no knowledge on this subject could be bad for your ride. shorts blown fuses and broken wires could cost a bunch of money. But if you want to gamble, a wire starts from the positive side of the system and will go from one brake to the next brake to the clutch to the on on the cruise to the throttle position sensor. If everything in this line does not show a fault then I will tell you how to proceed to the next.....
gibson is offline
post #9 of 13 (permalink) Old 04-30-2012, 05:27 PM Thread Starter
Guys,
Local dealer said they checked it out. They took the bike out for a test ride and said they had to press the button VERY hard to get it to engage and then it cut out just as they were returning from the test ride. They think it is the control panel as they have checked all the connections. They said Victory UK will not honour the warranty as I bought from Victory USA, so now I am stumped and dissappointed!
ukflyer is offline
post #10 of 13 (permalink) Old 04-30-2012, 05:41 PM
gibson's Avatar
http://www.brakeawayproducts.com/app...=6&model_id=29 this is the cruise I am going to buy.. Say what you want but this old reliable technology...
gibson is offline
