Cranks but won't start - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 04-07-2012, 09:18 PM Thread Starter
Default Cranks but won't start
It ran fine yesterday and today it started with the enricher, turned off the enricher it stalled and now it won't run. The fuel pump is ticking, the lights are bright. The battery is the original 2007, but I feel if it cranks it should be strong enough to start. Going to spray staring fluid in the cyclinders to see if it's starving for fuel, I will then crank it with the plugs out to see if I have spark. Any other ideas? are there fuses I should be looking for?
2007 Jackpot Premium
HID Headlight
Swept Exhaust
Torque Tubes
Monster Baffles
Power Commander
Too much chrome and add ons to list.
:soapbox:Ban "TAR AND CHIP"
MSchneid is offline
post #2 of 12 (permalink) Old 04-07-2012, 09:52 PM
Plugs fouled, try new set of spark plugs.
Bikendad is offline
post #3 of 12 (permalink) Old 04-07-2012, 11:12 PM
turn the key on all the way !!!!!
2007 VEGAS ( BIG BALLS )
www.houseofthunderusa.com
DAREDEVIL is offline
post #4 of 12 (permalink) Old 04-08-2012, 06:47 AM Thread Starter
New E3 plugs < 50 Miles, If the lights are on I would assume the key is on.
What about the fuel pumps, bad seals? I saw another post where a 2007 Vegas had a bad pump.
Do you think this ould be covered under that 5 year warranty?
HID Headlight
Swept Exhaust
Torque Tubes
Monster Baffles
Power Commander
MSchneid is offline
post #5 of 12 (permalink) Old 04-08-2012, 10:50 PM
Stupid question but, do you have fuel?
2014 XC, timing wheel, HIDs, PC-V tuned by Rylan, HMC Air ride, HMC Eliminator
Infidel1Actual is offline
post #6 of 12 (permalink) Old 04-08-2012, 11:14 PM
Vic's are notorious for being a pain if the battery is tired.
One thing popped in my head though. You can spray carb cleaner into the throttle bodies to see if you get some action. If you do; I'd look at the fuel filter as being the culprit.
But the battery being 5 years old would be something I'd look at first. It's time to replace it anyway...
post #7 of 12 (permalink) Old 04-09-2012, 09:30 AM
New Member
Alot of the efi systems will not work if cranking voltage gets lower than 9 volts. Always remember the Battery is the heart of the whole electrical system, in my Shop I have seen alot of simple problems caused by a bad battery.
chubby5258 is offline
post #8 of 12 (permalink) Old 04-09-2012, 09:57 AM
Kuchera89's Avatar
my 07 hammer just got her 3rd battery...
the last owner put a very cheap carquest (was 16 instead of the ytx20) battery in and im pretty sure it is right around a year old. i went with the yuasa for alittle more $.
take it somewhere and get it load tested, dont just check the voltage, mine was reading 12.50 but failed the load test miserably, it started the bike great 2 times earlier in the day, then boom, nothing.
i would still guess spark plugs first tho, they are cheapest place to start, even if yours are still new, nothing wrong with spares. i fouled mine out on the kingpin a couple weeks ago right when i got it. but my bike was full of old fuel, had been sitting, and somone had messed with the throttle to where you had to leave the enrichener half on just to get her to idle warm...
2007 Hammer S 100CI
S&S air cleaner, PCIII, SRVT clubs exhaust, Avon grips.
2006 Kingpin 100CI
stage 1, touring setup to come soon...nm bought a XC.
2013 Sunset red and black XC
Kuchera89 is offline
post #9 of 12 (permalink) Old 04-09-2012, 11:16 AM
Doesn't really matter how new the plugs are if you started and stopped it without it getting hot, especially with it cutting out when you had the enricher on, they could be fouled.
Bikendad is offline
post #10 of 12 (permalink) Old 04-09-2012, 04:17 PM
You say the fuel pump is "ticking"? It should Hum for about 3 secs and shut off when the switch is pressed to Run.Do you hear this? I ask cause i had a Bad fuel pump on a 2004 that had 417 miles from the guy leaving gas in there the year or years before. You can also test it with a test light at the fuel pump connector to make sure its getting the juice it needs.
________________________________________
2004 Vegas
Oldcarjunkie is offline
