Running rich and some backfiring - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 04-08-2012, 10:53 AM Thread Starter
Default Running rich and some backfiring
I have a 06 hammer with swept pipes and an S&S airbox. Had the bike flashed with the S&S download at dealer but she still is very ruff on start up till she gets warm. She also seems like she is running rich( black smoke on hard throttle) with the occasional backfire on roll off of throttle.My question is do I need a fuel controller and if so will I need to get reflashed to stock or can I just plug and play? Or do I need to look else where to solve this issue?Any help will be greatly appreciated cause I love this bike and I don't want to hurt the motor, I put her though enough pain trying to carry my big 6'5" 375 pound ass around so I need to make sure she is running right!! Thanks for any help at all my brothers!!!!
2006 Hammer premium
S&S Intake
Slash Ness exhaust
Air Ride suspension
Muffin Man 114 is offline
post #2 of 9 (permalink) Old 04-08-2012, 11:02 AM
Had similar issues with backfiring, I've ordered and plan to install a Power Commander 5 and the autotune module. Then get a dyno tune if i can't fix it myself w/ the software
My understanding is the flash doesn't matter once you add the PC.
https://www.victoryforums.com/showthread.php?t=10632
The thread above is my reference for the install.
2008 Victory Vegas 8-Ball
jebz240 is offline
post #3 of 9 (permalink) Old 04-08-2012, 11:11 AM Thread Starter
Thanks for the input bro. Unfortunately I have an 06with the open loop so the auto tune is not an option for me.
2006 Hammer premium
S&S Intake
Slash Ness exhaust
Air Ride suspension
post #4 of 9 (permalink) Old 04-08-2012, 11:13 AM
I guess you could look at the Powercommander III USB
jebz240 is offline
post #5 of 9 (permalink) Old 04-08-2012, 11:38 AM
CrossRoads's Avatar
Or, if you like full control over your fuel controller, allowing for adjustments on the side of the road - no tools, laptops, etc., you might want to consider Lloydz' Victory Fuel Controller, gen 3 (VFC-III), for $265. For your model year you will have to revert to the stock download prior to install.
CrossRoads is offline
post #6 of 9 (permalink) Old 04-08-2012, 11:49 AM
Actually you could use the PC V, the swept exhaust has a bung already welded to each pipe so you would have to buy two O2 sensors.
I had a 2007 with the power commander III and it still back fires on decel unless you hold the throttle slightly open. I have tried everything and it still pops on decel.
I believe for emissions and fuel economy Victory totally shuts off the fuel once you let go of the throttle so you get a lean condition and pop.
Make sure your idle is at 1,000 to 1,100 rpm this will be the best you can do.
2007 Jackpot Premium
HID Headlight
Swept Exhaust
Torque Tubes
Monster Baffles
Power Commander
Too much chrome and add ons to list.
:soapbox:Ban "TAR AND CHIP"
MSchneid is offline
post #7 of 9 (permalink) Old 04-08-2012, 12:31 PM
Some users reported the following:
3. Tuning notes (Gathered from multiple site)
-If deceleration backfiring occurs after loading base maps and tuning-
"Try zeroing out your 0% and 2% columns, both in the AFR table and the main fuel table, then just set your idle AFR to 13.2 (0% at 750-1250rpm) only. I think the Autotune tries to lean out the 0% and 2% columns too much because most of the time spent there is decelerating."
jebz240 is offline
post #8 of 9 (permalink) Old 04-09-2012, 05:15 AM
DunedinDragon's Avatar
I'm not so sure about the PCV and Autotune on an open loop system. Even if the pipes have a bunghole, I doubt the bike's ECM is setup to monitor and adjust the fuel feed based on the O2 readings. Obviously the PCV and AT are capable of that, but would they do it even if the ECM doesn't, or is their operation predicated on the ECM's mapping logic? Good question. If it does, then that means you could turn an open loop system into a closed loop just by adding a PCV and AT.
As far as decel popping, I fixed mine by slightly increasing the numbers in the fuel table (NOT the AFR table) at the 0% throttle position in the 750 - 1750 range. When you decelerate you don't immediately return to idle rpm as detected by the ECM and PCV, and it's in that range where the popping occurs. Just make sure you don't enter any AFR values in those columns as that would calculate a new trim number which would eventually overwrite your fuel table entries when you applied them.
2012 Victory High Ball
Victory Stage 1 swept pipes and performance air filter
PCV and Autotune
DunedinDragon is offline
post #9 of 9 (permalink) Old 04-09-2012, 08:27 AM
I have a 06 And have the s&s air box & download My bike has never run better Is it possible the download did not take ?
2006 kingpin
S&S Intake
Hard Krome 3in big straights
Ness Ram bars
tfkp is offline
