Air Filter and Plugs / XC / 11,600 Miles - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 04-25-2012, 11:19 AM Thread Starter
BeoBob's Avatar
Question Air Filter and Plugs / XC / 11,600 Miles
Cross Country with the Vic Stage 1, and have about 11,600 miles on the bike.
Replaced the Air filter and plugs yesterday.
Book calls for an air filter at 10,000 miles, so I was a little over. It looked like it had 50,000 miles on it!!! It had bugs and bits of all kinds of stuff stuck in it and was so black that I wasnít sure it was a cloth filter (versus paper) until it was clean. Is this normal? Is there a different clean interval (versus change) for the Stage 1 filter that no one told me about?
I used some Dawn and hot water in a pan to clean the filter, and after a few cycles of that it came good and clean. I put it in front of a box fan to dry. Once clean and dry I could see the green of the grass through it. The holes in the filter media look pretty big, and in several places the holes are as big as the diameter of a standard sewing needle. Is this normal? Doesnít seem right to me. I think Iím going to get the Loydz filter when available anyway. The holes on the OEM one are just too big for the engineer in me.
I used standard K&N oil on the filterÖ is this OK?
Book calls for 30,000 miles before the first plug change. They looked pretty black for 11,600í. There was no way I was sticking those things back in. $10.70 and now there is fresh electrodes in there. Again, is this normal?
Thanks.
2013 Cross Country Tour: Custom paint, stage 1 exhaust, Lloydz Hi-Flow air filter, cams (HOH-VM1-DR), timing gear (HOH-PTS), Power Commander V, Auto Tune module, Gustafson flip shield, OEM passenger backrest with Cycle Ops luggage rack, Vic HID, heel shifter, Rockford amp, Infinity speakers all around.
2011 Cross Country: Burnt and Traded
BeoBob is offline
post #2 of 3 (permalink) Old 04-25-2012, 04:58 PM
I cleaned my Vic Performance air filter for the fourth time two weeks ago at 10,300 miles. Been cleaning it about every 3k, but did it a couple times between 500 and 1500 miles. That sucker gets dirty, no way I can leave it in for more than 5,000 miles and my gut says 3,000.
I've been using the standard K&N charge kit from AutoZone, comes with spray cleaner and oil.
I too plan on moving to Lloydz filter once it becomes available.
Tripntx, Retired US Air Force, 2A390 Aircraft Superintendent
2012 Red Cross Country Tour (on order 30July2011)
Llyodz VM-1 Cams
Settled on D&D exhaust
Victory Performance filter and seal removed
PCV & AT & LCD-200
Passenger hand holds, Passenger arm rests, side bag rails
'06 FJR1300AE
K&N, Full Holeshot exhaust system, PCiii, Dark side with 17" car tire on rear
tripntx is offline
post #3 of 3 (permalink) Old 04-26-2012, 02:45 PM Thread Starter
BeoBob's Avatar
Thanks for the input Trip.
BeoBob is offline
