XCT oil light - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 04-27-2012, 05:10 PM Thread Starter
Default XCT oil light
Happened today for the first time. After I shut the bike down the red oil light came on for about 5 seconds. No other dash lights did. Oil is good, on start up light goes off as advertised. Anybody have this happen to them or know what's up with it. Thanks
Mike
2012 White Cross Country Tour
mikiep is offline
post #2 of 8 (permalink) Old 04-27-2012, 05:36 PM
Not sure I understand but when I hit the kill switch the oil light stays on until I turn the key off.
Now owns 2012 Cross Country Tour! 3-9-12
http://patsrides.blogspot.com/
pat0021 is offline
post #3 of 8 (permalink) Old 04-27-2012, 08:56 PM Thread Starter
Same with mine except once I turn the key off the light stays on for about 5 seconds.
Mike
mikiep is offline
post #4 of 8 (permalink) Old 04-27-2012, 10:52 PM
Bob C350's Avatar
My 2010 does the same and always has.
2010 Cross Country Midnight Cherry
Touring trunk, Heated seat and grips, Vic closeouts for cold weather, Ebay fork lowers, All the low cost mods
Bob C350 is offline
post #5 of 8 (permalink) Old 04-28-2012, 12:59 AM
Default Seen the light!
If the light comes on after you hit the kill switch it is just doing its job. The oil pressure sender senses that there is no oil pressure because the engine stopped turning, thus no oil pressure.
Speedblue is offline
post #6 of 8 (permalink) Old 04-28-2012, 06:04 AM
Is your oil light an incandescent or led?
If its an led, I would suspect your seeing
a capacitor bleeding off. Leds draw next
to nothing for power.
Steve
ch55 is offline
post #7 of 8 (permalink) Old 04-28-2012, 05:36 PM Thread Starter
Thanks guys, there is no problem with the bike. It only happens if I use the kill switch. If I use the key only light doesn't come on. Thanks
Mike
mikiep is offline
post #8 of 8 (permalink) Old 04-28-2012, 05:56 PM
gibson's Avatar
Steve
you are correct
2012 Fireball Jackpot
gibson is offline
