too much oil - Victory Forums - Victory Motorcycle Forum
post #1 of 30 (permalink) Old 04-30-2012, 01:24 PM Thread Starter
Default too much oil
Strange issue here folks. I've worked on cars my whole life, but never on motorcycles. For my second oil change at 5200 miles I'd thought I would tackle it myself.
The manual calls for 4.5 quarts. Well with normal motor oil there is a window on the side of the bottle. Not on Victory oil bottles though. So finding the halfway mark of the bottle wasn't as apparent. Point being is I believe I put too much oil in. The scoot runs fine, starts fine, seems fine with one exception: When I start the motor when its warm, say after its been running and I stop for gas, the low oil indicator blips on for less than half a second. It disappears right away and the motor runs as good as always. My concern is I never saw this until I changed the oil. I checked the oil level per the instructed procedure as I was highly doubtful that it was low. The stick was reading a bit high (about 1/8" over the full line). I didn't want to replace the copper washer, so I removed the oil through the dipstick hole via a turkey baster. Checked the oil and the level seemed fine, but still see the indicator upon a warm startup. When starting from a cold state there is no low oil indication. I feel really stupid considering my background, but I guess everyone makes mistakes.
My question is did the small amount of overfill permanently damage something? I rode about 300 miles since the change and before i noticed the indicator. Like I said, runs fine, but the indicator popping up on warm start up concerns me since it wasn't there before.
Thanks in advance.
2012 Vegas
horrace is offline
post #2 of 30 (permalink) Old 04-30-2012, 01:58 PM
I'm not too sure if it would be from too much oil, as the dealership always puts a full 5 qts in my 2011 XC, and it runs beautifully, never had an issue with oil pressure at all. As matter of fact I discovered it was more than normal when I was checking the level and more than a few drops spilled out and the level never went down below the fill line.
tydesigns is offline
post #3 of 30 (permalink) Old 04-30-2012, 02:04 PM Thread Starter
Thank you TY. I guess it could have really been low. Which makes me feel a bit better as with any IC motor it's always best to have too little than too much. Just don't understand why the indicator only shows up with a warm motor. Not even half a second, but it does show up.
Edit: do all victorys have the same oil capacity?
2012 Vegas
horrace is offline
post #4 of 30 (permalink) Old 04-30-2012, 03:10 PM
Tip to those who have to add half quarts: weigh the full quart container and have the scale close by as you pour, checking the weight occasionally. When you get to half the original weight, stop. I find a full quart usually weighs two pounds, so I stop at one pound. Simple, eh?
post #5 of 30 (permalink) Old 04-30-2012, 03:43 PM
My Harley trick, find a pint oil container or pint milk container and empty it (was fork oil for HD) and put oil in it and use as needed. Two pints = one quart. Good excuse for a trip - sometimes uses just a little oil and quarts take up too much room.
PaulK
Freeport, IL
2011 Vegas 8-Ball
Tri-Pro Stage 1 Exhaust
Mini Standard Windshield
Rear Lugage Rack (modified to fit)
Kingpin rear seat and bar
long Progressive Suspension rear shock
TCB brake system on rear brake
Fiberglass saddlebags (lockable & don't leak)
LED headlight
Magnum front cast rim
Magnum front fender
FilterMag
Signal Sorcerer
Animal Alarm System
PaulK is offline
post #6 of 30 (permalink) Old 04-30-2012, 04:04 PM
ndabunka's Avatar
Always measure the oil levels with the bike VERTICAL instead of while resting on the kickstand. That will give you your TRUE levels. I recently did my first @ 5,500 and noticed that when in the kickstand 4 quarts was close but as soon as I stood the bike up, I was low so I added the additional required 1/5 quart. I simply "guesstimated" and got it pretty close. With the Victory nozzle that comes in the oil change it was fairly easy to "get it right".
It's not just any victory.... It's MY Victory!
2011 Victory Ness Cross Country #120
Ness Thunderheaders
Ness Knurled Highway Pegs/KwelMetal Brackets
Ness Radius laydown license
Chrome CAM Tension Covers
Red Engine Bolts
Madstad System
DIY Garage Door Opener
Victory Chrome Saddle Bag Lid Rails
Küryakyn Upper Fork Shrouds
Küryakyn Lower Fork Covers
Power Commander V Tuner
Power Commander AT-300
Hertz HCX 165s Speakers
JL Audio HX280/4 Bridged 140w
ndabunka is offline
post #7 of 30 (permalink) Old 04-30-2012, 05:16 PM
Victory of Southern Maryland told me that if you leave it on the kickstand and check it, it will be the 1st three threads = full. Now I haven't changed my own oil just yet, but they told me they fill it up pretty full.
post #8 of 30 (permalink) Old 04-30-2012, 06:04 PM Thread Starter
Thanks for the replies everyone.
I check the oil with the bike vertical and at "normal operating temperature" per the manual. I don't have a temp gauge, so I just wait until my rpms read about 900rpm, which is what it is idling while riding.
I've looked everywhere I can see and there doesn't seem to be any leaks from a popped gasket so I know that's okay. I'm just concerned about any internal seals that I CAN'T see. Being new to the freedom motor, I'm not too knowledgeable about their inner components. I know everyone says that these motors are bullet proof, but I don't think they're bullet proof against negligence.
2012 Vegas
horrace is offline
post #9 of 30 (permalink) Old 04-30-2012, 06:59 PM
So does your manual say 5qt? I dounght it.
Your dealer must be charging you for something your not getting.
All the 2008 an up motord take 4 1/2 qts when bike is straight up an down.
Ask dealer why your being charged for 5qts when the bike only takes 4 1/2 qts.
post #10 of 30 (permalink) Old 04-30-2012, 07:35 PM
New Member
Victory of Southern Maryland told me that if you leave it on the kickstand and check it, it will be the 1st three threads = fulll.
TrashmanNYC is offline
