Gas tank plug - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 04-30-2012, 04:30 PM Thread Starter
ROADWARRIOR40's Avatar
Default Gas tank plug
Ok guys, I searched the forum for any others who have had this problem and found nothing. The 5" Dia plug in the bottom of the tank uses two o-rings. The ones that were on there did not fit tight enough in the groove to stay in place during re-instillation. The seating surface is inside of a c-bore and the plug has a flange, so there is no way to hold the o-rings in place while loading (like when squeezing piston rings). I purchased new o-rings from the victory dealership and they gave me a different part number than the one online. I do not know if the other part number is any smaller but the old ones were big too. I already damaged one of the new rings by having it pinched (which i could not see till i removed the plug to try again). I am trying to find the next size smaller o-ring on my own but I am having no luck.
part # 5412071
'11 Cross Roads
Bassani slip-ons
Lloyd air
'05 VTX-C, '06 Vic Jackpot
If Your Not Living On The Edge, Your Taking Up Too Much Space
ROADWARRIOR40 is offline
post #2 of 10 (permalink) Old 04-30-2012, 05:44 PM
gibson's Avatar
is it like this???
2012 Fireball Jackpot
gibson is offline
post #3 of 10 (permalink) Old 04-30-2012, 05:47 PM Thread Starter
http://www.cyclesolutions.net/product/sku-WD-5412071
this one is bigger than any in that set
'11 Cross Roads
Bassani slip-ons
Lloyd air
post #4 of 10 (permalink) Old 04-30-2012, 05:53 PM
gibson's Avatar
Attachment 5866 This is on a 2010 Jackpot, so I am guessing this is what you are talking about..9 5413346 Seal, Fuel, Molded
gibson is offline
post #5 of 10 (permalink) Old 04-30-2012, 05:58 PM
gibson's Avatar
Attachment 5867 5412071 O-Ring 2006 Jackpot
gibson is offline
post #6 of 10 (permalink) Old 04-30-2012, 06:15 PM Thread Starter
item 7 in last schematic
'11 Cross Roads
Bassani slip-ons
Lloyd air
post #7 of 10 (permalink) Old 05-01-2012, 09:54 AM Thread Starter
I have tracked down an o-ring number.
there is an aerospace spec for o-rings. The floor of the grooves are 4.650 Dia. and the ring I found is 4.609. The link I am including is for the wholesaler. I am purchasing 20 of the gasoling stable o-rings. If anyone wants a few of them, contact me.
-247 is the 4.609 Dia for our bikes
http://www.oringwarehouse.com/files/...-sizechart.pdf
'11 Cross Roads
Bassani slip-ons
Lloyd air
post #8 of 10 (permalink) Old 10-11-2012, 10:27 PM
is there a trick to getting the 4.6" plug out of the tank. i removed the "fastener" that fits on the inside groove. but the big plug seems to be giving me trouble. how to actually remove the plug? pry it out?
05' Hammer
Lamborghini Grey/Semi Flat clear
LED turns
Slasher pipes
Avon cobras F/R
GRAND RAPIDS, MN
faslane is offline
post #9 of 10 (permalink) Old 10-12-2012, 11:28 AM Thread Starter
I made a slide hammer with a metric screw. if you have a screw that is long enough you can wiggle it out.
By the way: if you need new o-rings, send me you address and i will hook you up. I bought extras. The stock ones are VERY hard to install because they fit too loose.
'11 Cross Roads
Bassani slip-ons
Lloyd air
post #10 of 10 (permalink) Old 10-12-2012, 03:06 PM
Ferta_McDaniels's Avatar
This is a tool made for removing the plug. You could probably fabricate one much cheaper. Just put a 8mm bolt and nut through the center and screw it into the plug. Then just tighten the nut and out it comes.
https://polaris.spx.com/Detail.aspx?id=139&cat=4
PFloyd (Ferta)
2014 Vision Nuclear Sunset
XM Radio Module
Sequential Turn Signals F/R
1/4 Turn Throttle Ring
HID Headlights & Cyclops
Vic Shop Tweaks: 124 HP / 121 Torque
04 Purple Thunder Kingpin (Sold)
Ferta_McDaniels is offline
