fix a lean mix? - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 05-15-2012, 09:50 AM Thread Starter
kingslyzissou's Avatar
Default fix a lean mix?
I was doing some maintenance on my ride this past weekend and pulled the plugs for inspection. They were pretty white, indicating a lean mix. From what I hear this is normal for a stock Vic.
Is there a way to adjust this at home with any type of mechanical adjustment or do I need to take it to the dealer and have them adjust it programmatically? Would they even do this without adding any mods? I would just like to make it a touch more rich considering the temps are heating up here and I'd like to see if I could get it to run cooler.
2012 vegas 8ball
kingslyzissou is offline
post #2 of 15 (permalink) Old 05-15-2012, 10:21 AM
Un hook your 02 sensors and it will richen up your motor.
Just un plug them and tuck the wires in so they don't hang down.
No it will not hurt your motor and if have modified exhaust it will take most of the pop out.
post #3 of 15 (permalink) Old 05-15-2012, 11:06 AM
+1 on what VJ said. Also; pulling your plugs after the bike has been sitting isn't really the best way to check them. It'll give you an idea but if you really want to see what's happening at speed, say 60 mph or so, get out and ride the bike at that speed for a bit then simultaneously let off the gas, pull the clutch, and hit the off button and roll to a stop braking safely. Then pull the plugs. You will then see what the mixture is when you are under load and how it spends most of it's time while running.
Just a bit of extra info if you wanted to try that before and and after you disconnect the O2 sensors.
Of course; getting a fuel tuner is the best overall choice but pulling the O2 sensors will get you near where you want to be and you will love the cooler running motor.
post #4 of 15 (permalink) Old 05-15-2012, 02:26 PM Thread Starter
Great! Thanks guys.
I know a FC is the best way, which I do plan on adding (PCV w/AT), but it's gonna have to wait a bit. In the meantime, this is nice.
Thank you very much.
2012 vegas 8ball
post #5 of 15 (permalink) Old 05-15-2012, 05:32 PM Thread Starter
Well in thinking about it, now I have to ask:
If having O2 sensors makes your ride run lean/hotter, then why were they installed? Seems an all around better setup without them.
2012 vegas 8ball
post #6 of 15 (permalink) Old 05-15-2012, 06:00 PM
The Simple answer.......EPA !!
2010 XC Midnight Cherry
cams/D&D
2009 Ness Vision
116 Big Bore
"The Millinium Falcon"
Blueline is offline
post #7 of 15 (permalink) Old 05-15-2012, 06:36 PM Thread Starter
They are often the best answers. Thank you Blueline!
2012 vegas 8ball
post #8 of 15 (permalink) Old 05-16-2012, 05:43 AM
DunedinDragon's Avatar
And the complex answer...
The O2 sensors are a major component in a closed loop fuel injection system. It allows the ECU to make adjustments to your fuel mixture to accommodate all sorts of variables such as altitude, load and temperature...not to mention managing fuel economy. However, political pressure has forced a situation in which the setups on these bikes are set unreasonably lean to meet EPA standards.
I only point this out because it's important to understand that you don't get something for nothing. Disconnecting the O2 sensors may benefit your bike in terms of richening your mixture, but you will lose certain other benefits like responsiveness under load and fuel mileage. That's the reason adding a fuel controller is truly the right fix, which you seem to understand.
Disconnecting the O2 sensor isn't really the "best" answer...just the quick answer.
2012 Victory High Ball
Victory Stage 1 swept pipes and performance air filter
PCV and Autotune
DunedinDragon is offline
post #9 of 15 (permalink) Old 05-16-2012, 09:29 AM
And as a by product of all this (which started in 2006), manufacturers have increased the engine size to try and keep some power with the motors all congested and snuffled up. HD went from 88ci to 96 to 103ci. Vic has gone from 92 to 100 to 106ci. So at the end of the day, it's not all bad.
cams/D&D
2009 Ness Vision
116 Big Bore
Blueline is offline
post #10 of 15 (permalink) Old 05-16-2012, 04:23 PM Thread Starter
Well I did understand it, but now I understand a whole lot better. Thanks Dune. That all makes a good amount of sense.
So I did this and this is what I've found on a short ride: Motor is muuuuuuuch cooler. I can't even feel it through my pant legs now (jeans). 100* today and 104* yesterday. Didn't feel one iota of heat from the engine. Awesome result there. I did notice the aforementioned loaded power loss, specifically at around 3500 rpm. I just didn't get the immediate acceleration I was used to. I think I can live with that for the next few months though, or at least until I get a FC.
As a note for anyone else doing this. Disconnect the O2 sensor at the connecter about 6" back from the sensor, not at the sensor itself. I tried for about 30 seconds to disco from the sensor and ran into a lot of resistance. Then I said to myself "hey self, you have a service manual. Look it up.". Sure enough, manual says NOT to disconnect from the sensor, but from the connector a little ways back. Just FYI.
Thanks again everyone. As soon as I can I'll order my PCV w/AT. It almost seems like this should be the first performance mod even before exhaust or a new air box is installed. So I'll pick this up before my Thor and TT.
2012 vegas 8ball
