how to drain gas tank - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 05-20-2012, 12:01 AM Thread Starter
Default how to drain gas tank
Hi i have a tank on a hammer i need to drain and i know when you remove the fuel line alittle gas leaks outs thats in the fuel but how to you get the gas out? Thanks
hammer316 is offline
post #2 of 12 (permalink) Old 05-20-2012, 12:19 AM
Bad V V's Avatar
Go to your local auto parts store and get a siphon. It's less than 10 bucks and it does he trick.
2003 Victory vegas
Bad V V is offline
post #3 of 12 (permalink) Old 05-20-2012, 09:52 AM Thread Starter
i was originally going to do that but i figured there has to be a way to drain a gas tank.I know with carberated bike just disconnect the fuel hose from the petcock attatch new hose going to container open and away ya go.So you saying on a fuel injected bike there is no other way to drain it other then siphon the gas out?
post #4 of 12 (permalink) Old 05-20-2012, 10:27 AM Thread Starter
just thinking if i disconnect the fuel line from the tank and connect another fuel line from tank to jerry can and turn on igniton wont the fuel pump drain the tank?
post #5 of 12 (permalink) Old 05-20-2012, 10:38 AM
You could do that but then you take the chance of burning up the fuel pump.
Open the gas cap and tip the tank over.
As long as the fuel pump is in the tank you;ll have some gas caught in there.
How bone dry do you want it? What are you doing to the tank that you need all the gas out?
post #6 of 12 (permalink) Old 05-20-2012, 10:43 AM Thread Starter
Well i have 2 bikes and havent drove the hammer for a long time and when i put the bike aways i had a full tank so good chances are the gas isnt good so i wanted to drain the tank and put fresh gas in.I guess i could siphon most of it out but figured should be away to drain a tank.About burning out the fuel pump isnt the fuel pump running all the time anyways?
post #7 of 12 (permalink) Old 05-20-2012, 11:10 AM
I don't think you can use the fuel pump trick. I tried this on an EFI Harley one time and there was a sensor somewhere that stopped the fuel pump after a few seconds. Maybe a fuel pressure sensor. No pressure no pumpy after the initial pumping to prime the EFI.
post #8 of 12 (permalink) Old 05-20-2012, 05:22 PM
karmobRob's Avatar
The ecu will only run the fuel pump for a few seconds when the engine is not running.
ROUTE 6 MC TASMAN NEW ZEALAND
2002 V92C CUSTOM
2012 HIGHBALL [ Sold ]
karmobRob is offline
post #9 of 12 (permalink) Old 05-21-2012, 10:24 AM Thread Starter
Well i guess its siphon time!
post #10 of 12 (permalink) Old 05-21-2012, 12:20 PM
StL Mike's Avatar
Not trying to hijack this thread,
My service manual says that I need a special tool from the dealer to prevent gas from coming out of my tank when when I remove it to change the air filter. Do I really need to buy that tool?
Thanks,
Mike
2012 Pearl White Cross Country Tour
D&D Wrapped Slipons, with Lloyd's High Flow Airbox
Lloyd's 116 Kit, Touring Cams and Timing Gear
Unlocked ECU
Power Commander V and AT
2" Pull Backs
Victory rider's Backrest
Victory Luggage Rack
Madstad 13" Windshield and Brackets
StL Mike is offline
