Starter Clutch Going Out? - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 05-26-2012, 10:04 AM Thread Starter
Default Starter Clutch Going Out?
I have what I think is a starter clutch getting ready to go out on an 04 KP. I hear a high pitch steady sound that's different than the gear mesh whine most of us are use to. It also makes a fairly loud screeching noise after I turn off the motor most of the time.
Does this sound like the starter clutch on its way out?
If so; are there any special tools needed and do I need to drain the oil to pull the primary cover. Should I change primary gasket. I ask because I did the cams on my XC and reused the gaskets even though I had new ones. I'm assuming the primary gasket is different between the two bikes. Yes?
BBob is online now
post #2 of 2 (permalink) Old 05-26-2012, 10:19 AM
For sure drain the oil and to be on the saft side I would put in a new peimary gasket.
Don't forget to un hook the battery.
