Clutch lever and shifter lube - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 05-30-2012, 10:28 AM Thread Starter
kingslyzissou's Avatar
Default Clutch lever and shifter lube
The service manual calls for Molly Paste to lube the clutch lever. Does anybody know where this can be acquired at a local store, or do I need to order it? Or is there something else that is acceptable? I've read a few posts if cables last a good while. What do those that have experienced use?
Also I have read it's a good idea to lube the two points on the shifting lever. For those that do this, what do you use?
2012 vegas 8ball
kingslyzissou is offline
post #2 of 5 (permalink) Old 05-30-2012, 11:41 AM
colecrazy's Avatar
ARP lube is a moly paste. http://www.summitracing.com/expertad...bly-Lubricant/ Go see Tim at Tuf-Enuf marine, He can hook you up with some. A little goes a longs ways
05 Vegas Premium > Stage 1, Lowered (1.5 links,LOW shock,Ness 1"drop fork kit) Fly Bars, Raven Seat, HID Bullet light, LED Turns, More Chrome.
colecrazy is offline
post #3 of 5 (permalink) Old 05-30-2012, 12:09 PM Thread Starter
Thanks Cole. I'll check him out this weekend. I've found it online and from the looks of the container I should only have to buy it once
2012 vegas 8ball
post #4 of 5 (permalink) Old 05-30-2012, 01:52 PM
ks_greg's Avatar
Default Clutch lube
Here's a shot from the manual.
I just bought a can of moly lube from the local auto parts store.
Rolled the shift lever at the case to the right, this will give you enough slack to get the cable end out of there, and enough slack to get the clutch handle out.
You will see there is a smear of grease on the top and bottom of the clutch handle. Just put a small smear of fresh lube there. Put some grease on the ball end of the clutch cable at the handle, then put it back together.
Pull the slack down, grease the ball end at the tranny case, connect the cable, and roll the pivot arm back to the left.
Wichita, Ks.
Prior Rides
'09 Kingpin 8Ball
'06 HD Road King
'06 Vulcan 900 Classic
ks_greg is offline
post #5 of 5 (permalink) Old 05-31-2012, 12:35 PM
The real trick is to use something that might last.
I pulled my clutch lever off by unbolting the one bolt. I cleaned every thing and re lubed with wheel bearing grease.
Mind you not a lot but a good even amount.
