noise from clutch - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 05-31-2012, 02:33 PM Thread Starter
jbb01's Avatar
Default noise from clutch
On the drive in this morning noticed rattling noise from clutch. Only made that sound when clutch was disengaged and in neutral. Sounded almost like a dry clutch from a duc. Any thoughts?
2011 Hammer 8-ball
VM-1 cams
TT intake
RPW Thor
Lloyds ATS
2001 Honda RC-51
jbb01 is offline
post #2 of 2 (permalink) Old 05-31-2012, 04:23 PM
half_crazy's Avatar
It's not the clutch, it's the torque compensator. They are rather noisy in neutral with the clutch out. If it bother you you can replace the wave washers in the compensator. If you do a search on compensator noise you'll find a list of part numbers.
2006 Victory Kingpin
half_crazy is offline
