Air filter removal - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 06-02-2012, 07:35 AM Thread Starter
maurice's Avatar
Default Air filter removal
I searched but found nothing on whether or not you can just loosen the tank bolts and raise the back end up high enough to get to the air filter. Little lazy. Rather ride.Thanks.
maurice
maurice is offline
post #2 of 6 (permalink) Old 06-02-2012, 08:12 AM
Garion12's Avatar
Maybe, but it could be awkward. I have never remove the whole tank on my CR. I just remove the seat, remove the tank bolts, then slide back the tank. I have never had an issue withe the hoses or bits and pieces under the tank breaking or being damaged. I just never feel like completely removing it.
2010 Cross Roads
Lloydz Air Filter
Lloydz Slip on Exhaust
Lloydz Timing Wheel 8*
LLoydz VM1-HPT Cams
Lloydz reflesh 6500 rpm
Dyno tuned by KMC 123 hp 121 tq
Garion12 is offline
post #3 of 6 (permalink) Old 06-02-2012, 03:44 PM
1bada66's Avatar
Remove the seat, remove the two tank bolts,(be careful to not drop the rubber bushings in to the frame. Don't ask.) and ground wire if you have to. Pull the tank back about half way then you can remove the two screws that hold the filter in. Be careful when putting the tank back in place. Do not force it down at all to line up the bolts. It cost me a $300+ fuel pump and fuel line. It should drop back down in place. If it does not, lift it back up and check the fuel line to see if it is recessed into the frame. If not turn it so it points directly to the rear of the tank.
Take your time and don't force anything and you will be fine.
66' Shovelhead (first bike)
11' Cross Country, Victory High flow air filter with sound strip removed, PCV with Auto Tune, Bassani 2 into 1 Road Rage, VM1-DR cams, timing wheel 4 deg advanced, idle air valve, Medium Flip windshield, Drivers back rest, Trunk, HID lights from http://www.victoryhid.com, and Stereo accessory pug in.
1bada66 is offline
post #4 of 6 (permalink) Old 06-05-2012, 12:20 PM Thread Starter
maurice's Avatar
Thanks for the info guys! I will certainly be very careful with the process and not loose any parts. Ride safe!
maurice
maurice is offline
post #5 of 6 (permalink) Old 06-05-2012, 06:57 PM
Also make sure your tank is secure somehow when you have it un-bolted and moved back so it doesn't tip off the bike while you're working on it (don't ask me how I know). You might want to have a second person around to help you with that.
40XC is offline
post #6 of 6 (permalink) Old 06-06-2012, 10:01 AM
depot picker's Avatar
I removed mine by disconnecting the vents, then lift it enough to gaet my right arm under it and release the fuel line. It will begin dumping fuel so have a plan to plug it.
When you reassemble it be very careful to make sure the fuel line is properly connected. Mine stayed on for a day then popped off whilr I was riding. I set a record for getting the seat off and reconnecting the fuel line. Keep your tools handy after you do it for a few days just in case.
depot picker is offline
