Help with cleaning fuel injectors on 99 V92C - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 06-04-2012, 08:20 AM Thread Starter
Default Help with cleaning fuel injectors on 99 V92C
I am trying to find information on cleaning the fuel injectors on my 99 Vic. The service manual has no reference to it. I have cleaned the throttle body throats and plates, lubed the cables and replaced all the filters in the fuel system. I would like to know if you can clean the injectors by hooking up to the pressure cap on the rail, after disabling the fuel pump. I have the 3M fuel injector cleaning kit with the adapters and fuel pressure gauge etc. Can this procedure be used on the bike?
ray2001 is offline
post #2 of 2 (permalink) Old 07-02-2012, 11:26 PM
Tims_04V92TC's Avatar
Just seen this post Ray. I havent seen anything in any of the forums or heard anyone speake of doing this for that matter. I have heard both pros/cons of Seafoam or the like for cleaning your fuel injectors. Most of the concerns seemed to be around the corrosion prohibitor in the tank. I have ran 1/4 can seafoam through two tanks and as far as I can tell, bike is runing fine. Red corrosion prohibitor is still very visible in tank. TB cleaning was the big ticket in improved performance to me.
Tim
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
