Fuel Controller - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 06-16-2012, 12:10 PM Thread Starter
Default Fuel Controller
Have saw a lot of discussion on fuel controllers and auto tune, so thought I would throw this in. Check out gmanindustries.com and look at the Bully controller. I had one of these on a Suzuki that I had and it really brought that bike to life. I contacted them because it shows up to 2008 year, but they told me it willl work on all current Victorys. It is a plug and play and preset or you can adjust for different modifications. I have nothing to do with the site, just thought you might want to check it out.
2012 Blue XC
joeg is offline
post #2 of 14 (permalink) Old 06-16-2012, 12:47 PM
half_crazy's Avatar
Exactly the same as a VFC III as in it's a Dobeck generation 3 unit.
2006 Victory Kingpin
half_crazy is offline
post #3 of 14 (permalink) Old 06-16-2012, 02:03 PM Thread Starter
Can you explain further as to what it is and if it's a good deal or not? I take that you mean Victory sells one like it?
2012 Blue XC
joeg is offline
post #4 of 14 (permalink) Old 06-16-2012, 10:47 PM
If it's the Dobeck style; just about everyone sells one with different badging on them. With Dyno Jet it's the Power Commander III.
It's a "Pots" style tuner or digitally adjusted which adjusts the voltage to make the ECM react the way you want it to in terms of enriching and leaning the AFR. Basically makes it tune like a carb so you have an idle, mid range, and WOT ranges to tune.
post #5 of 14 (permalink) Old 06-17-2012, 07:05 AM Thread Starter
Ok thanks. I know the one I had on the Suzuki sure made a difference. This would probably be my choice if I put one on the Vic later. It came with directions for adjustments for each stage you did to the bike. It work great. Take care and thanks for the response.
2012 Blue XC
joeg is offline
post #6 of 14 (permalink) Old 06-17-2012, 12:02 PM
half_crazy's Avatar
These types of controllers can only ADD fuel and only tune narrow parameters and are very limited.
The Power Commander can ADD OR REMOVE fuel and adjusts at:
0%, 5%, 10%, 20%, 30%.... and so on to 100% throttle
1000 rpm, 1250 rpm, 1500 rpm, 1750 rpm, 2000 rpm, 2250 rpm... and so on in 250 rpm increments
then you do the other cylinder....
If you're happy with 'close enough' then get a VFC or Bully or Anger Management or Cobra or Ness or whatever brand of 3rd generation Dobeck fuel controller you choose.
If you want it tuned RIGHT, you'll need the Power Commander. I have had both the VFC and the PC-III and there is really no comparison.
post #7 of 14 (permalink) Old 06-17-2012, 12:39 PM
Thanks for the clarification HC. I wasn't aware those others couldn't remove the fuel. I bet you really like the PCV with the timing control and rev extender, eh!
Too bad they don't work with the older open loop bikes. Do you know if any mods can be made to allow the PCV to work with the pre-08 Vic's? It would be interesting if adding bung's, Auto Tune, and a newer ECM or, just the ECM and dyno tune, would work.
post #8 of 14 (permalink) Old 06-17-2012, 12:46 PM
half_crazy's Avatar
Don't most PC-V users disable the O2 sensors? If so, what good is closed loop FI?
I am SOOOO GLAD I have a 2006/2007 bike. My rev limit and timing ARE modified. Newer is not always better and I have no use for auto-tune.
post #9 of 14 (permalink) Old 06-17-2012, 01:42 PM
Yeah. If they aren't using the AT the O2's are disconnected and/or removed. On a built engine like yours; I'd want a very good dyno tech to tune my bike too. Too bad there aren't very many of those around (in my experience). The AT on my XC tunes it better than anyone in my area for sure.
The simple Stage 1 that was done before I got either of the 04 KP's I currently have are more than adequate for my needs. I really wish there was an ECM flash for the basic Stage 1 plus Lloydz cams for the 106 motors. Sure would make things better all around.
I'm not as impressed with the Power Commander as you seem to be. They actually have a bad reputation around here for failing. Might have something to do with the extreme heat. That Cobra, set it and forget it, tuner sounds promising though. I wish I knew why Victory isn't marketing it. Sounds like what many of us are craving.
post #10 of 14 (permalink) Old 06-17-2012, 03:47 PM Thread Starter
Half Crazy, thanks so much as I really did'nt know how different they were. It always helps to talk to someone that has been there and done that.
2012 Blue XC
joeg is offline
