Cutting out at 2600-3000 rpm - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 06-20-2012, 06:51 PM Thread Starter
toejam's Avatar
Default Cutting out at 2600-3000 rpm
Here are my fuel tables, am trying to get autotune to dial things in, but running just terrible at about 2600-3000 rpm. Any knowledgeable suggestions Thanks!
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #2 of 5 (permalink) Old 06-21-2012, 11:30 AM Thread Starter
toejam's Avatar
Added trims and ignition tables
BadBoy Horn, PCV
2006 Hammer - Gone
toejam is offline
post #3 of 5 (permalink) Old 06-21-2012, 12:37 PM
depot picker's Avatar
With what little experience I have on it, those number look way out of where they ought to be. Then again, I don't have a cam and a big bore. I'm thinking if your map is known to be good, zero out the fuel tables and trims. The AT will figure the rest out.
depot picker is offline
post #4 of 5 (permalink) Old 06-26-2012, 03:25 PM
ChiTownVegas's Avatar
Replaced exhaust gaskets and zero'd out all my tables.
I then contacted DynoJet and they tuned it over the phone. Bike runs GREAT!
Now, I just need to get a better set of tires that will put the power down better
2012 Vegas 8 Ball
LLoydz VM1 drop in cams
LLoydz Adjustable Timing Wheel
LLoydz 1/4 turn throttle ring
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
Pirelli Night Dragon rubber
ChiTownVegas is offline
post #5 of 5 (permalink) Old 06-26-2012, 04:28 PM Thread Starter
toejam's Avatar
Turns out the AutoTune Module was bad, took it off as a suggestion by Rylan and walah, no problems! Sent it in for replacement.
BadBoy Horn, PCV
2006 Hammer - Gone
toejam is offline
