Rear Wheel Alignment on a V92C - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 06-22-2012, 08:24 AM Thread Starter
Keith Beck's Avatar
Default Rear Wheel Alignment on a V92C
I have a '99 V92c, and recently developed a wobble from the rear end... I have checked the tire pressure and it was a little low so I topped them off at 38 front, 44 back (PSI). Still has the shimmy.
Id like to check the rear wheel alignment next, can I do this without the special tool called for in the service manual? If so how?
Trying to check the simple things first; alignment, belt tension, then bearings. If I'm missing something please chime in.
Keith Beck
1999 V92c
Slash Cut Pipes
& Chip
Keith Beck is offline
post #2 of 3 (permalink) Old 06-22-2012, 09:17 AM
depot picker's Avatar
Prolly the tire itself.
depot picker is offline
post #3 of 3 (permalink) Old 06-22-2012, 09:25 AM
cornfedboy2000's Avatar
IMHO you'd be better off taking it to a shop. You might have broken a steel belt in the tire, or it might actually just be out of alignment, but either way you have to ask yourself if it's worth saving a couple bucks by doing it in your garage? I took my bike in this spring for tires, and they found 2 critical safety issues that I had missed... just sayin
cornfedboy2000 is offline
