Top Lamp ?? - Victory Forums - Victory Motorcycle Forum
post #1 of 5 (permalink) Old 07-07-2012, 07:19 PM Thread Starter
DakotaRider's Avatar
Default Top Lamp ??
Just finished removing and replacing my headlight and fairing (2012 Cross Country Tour) in order to tighten things up since my parking lot drop a couple of weeks ago. Now for my question....
whilst digging through the wires behind the light and fairing I came across one which made me stop and wonder. It was labeled "top lamp" and was not connected to anything else. Can someone tell me what the "top lamp" wire and connector are for? TIA.
Winston - USAF Retired
Current Bike:
2012 Victory - Pearl White XCT - Dutchess
Rapid City, SD
Previous Bikes:
02 Goldwing - Stream Silver Metallic GL-1800
07 Goldwing - Dark Orange Metallic GL-1800
DakotaRider is offline
post #2 of 5 (permalink) Old 07-07-2012, 07:49 PM
Do you have both High & low beam right now? I believe that is how the headlight is labelled if I remember correctly. 2 separate connectors to the headlight.
Randy
2011 Cross Country "Mistress", Imperial Blue, Stage1
2010 Kingpin "Pin" Midnight Cherry
Botein is offline
post #3 of 5 (permalink) Old 07-07-2012, 08:48 PM
StL Mike's Avatar
I can tell you that if you plug the connector that you found into your high beam, which it seems to fit, your high beam will come on as soon as you turn the key on and your high beam switch will no longer turn your high beam on and off, don't ask me how I know.
Mike
2012 Pearl White Cross Country Tour
D&D Wrapped Slipons, with Lloyd's High Flow Airbox
Lloyd's 116 Kit, Touring Cams and Timing Gear
Unlocked ECU
Power Commander V and AT
2" Pull Backs
Victory rider's Backrest
Victory Luggage Rack
Madstad 13" Windshield and Brackets
StL Mike is offline
post #4 of 5 (permalink) Old 07-08-2012, 02:17 PM
post #5 of 5 (permalink) Old 07-08-2012, 03:18 PM
depot picker's Avatar
There is a connector for the standard low beam and one for the HID low beam.
depot picker is offline
