Trouble Starting When Bike Is Hot (sometimes) - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 07-08-2012, 04:52 PM Thread Starter
Default Trouble Starting When Bike Is Hot (sometimes)
This has happened to me about 4 times now, and still haven't figured it out exactly. My best guess is vapor lock.
I have a 2012 XCT, everything is stock. Not long after purchase (<500 miles) I was in Denver, stop and go, and parked the bike. It was pretty warm, in the 90's, but not overly so. The bike sat about 10 minutes. When I went to start it, the motor wouldn't fire. I gave it a bit of throttle and finally got it to start though it sounded like crap at first until it smoothed out.
Last week I was in Chicago, it was a very hot/humid 100+ degrees. I stopped at a gas station to hydrate the wife and myself, but didn't fill up the bike. We each drank a gatorade (the humans, not the bike) and then got back on. Same thing as before, she (the bike) wouldn't fire. I hit the starter about 5 times before she fired and idled very rough, backfiring and running like crap until I got her revved up for a minute and it steadied.
A few days ago I was headed back to Colorado and was somewhere in Wisconsin. Again it was hot so I stopped to get a drink. Tried to start the bike and the same thing happened again. I popped the fuel lid right away to see if that helped and it didn't. I gave it a lot of throttle this time...enough to smell gas...and it finally started again rough idle until I got her revved up and then she ran smooth.
Any ideas? It sure acts like vapor lock, but I haven't seen any posts with a similar issue. I can stop in the exact same conditions with no issues.
2012 Cross Country Tour, Black "Raven"
2004 Honda Shadow 750 Rat Bike "Ratsy"
1998 Honda CBR 900RR "Beatrix" (as in Beatrix Kiddo)
Road Captain, Dirty Dozen MC, Denver Chapter
PakRat is offline
post #2 of 13 (permalink) Old 07-08-2012, 07:47 PM
cornfedboy2000's Avatar
Have to agree with you, totally sounds like vapor lock. Wish I had more insight than that.
cornfedboy2000 is offline
post #3 of 13 (permalink) Old 07-08-2012, 08:09 PM
CrossRoads's Avatar
Maybe your fuel pump gets lazy and sweaty when it's too hot.
How many miles do you have on the bike right now?
Try tightening your battery connections, and test it out again. 50% chance you have a slightly lose connection, which gets worst with thermal expansion. I highly recommend doing this before pursuing any other possibilities.
CrossRoads is offline
post #4 of 13 (permalink) Old 07-08-2012, 08:15 PM
ammo_umb's Avatar
You've popped the cap so you ruled out venting and vapor lock is unusual on FI engines. About the last option I can think of is fuel and they may only be a problem if you've always fueled up at the same station. If this is the case try fueling at a different station.
Retired USAF, IYAAYAS!
ammo_umb is offline
post #5 of 13 (permalink) Old 07-08-2012, 08:57 PM
Vapor lock on a fi happens after a heat soak, it gets so hot that the fuel vaporises in the injector before or between pulses. I've had it happen on fi cars, it's got nothing to do with cracking the tank
post #6 of 13 (permalink) Old 07-08-2012, 09:09 PM
saddlebag's Avatar
https://www.victoryforums.com/showthr...ght=vapor+lock
2011 Cross Roads
saddlebag is offline
post #7 of 13 (permalink) Old 07-08-2012, 09:17 PM
ammo_umb's Avatar
Cornfed,
I mentioned venting because there have been a few reports in the past of X-Bikes with fuel tanks that didn't vent properly. Vapor lock on FI has a little bit to do with the venting but doesn't happen often. This may have changed since the fuel formulas have changed, ethanol may cause fuel the vaporize faster which could lead to vapor lock.
ammo_umb is offline
post #8 of 13 (permalink) Old 07-08-2012, 09:18 PM Thread Starter
Thanks. I've been traveling, so the same station is not the problem. I do try to pick name brand gas...Shell, BP, etc so I couldn't discount something in the gas per brand, though that seems unlikely.
PakRat is offline
post #9 of 13 (permalink) Old 07-08-2012, 09:23 PM Thread Starter
Right now it's at 6500. This happened at under 500, and kind of randomly in between then and now. I would think thermal expansion would make the connection better! I will take your advice though and check the connections. It turns over just fine during this, just doesn't fire. Then after cranking several times it fires up with various throttle manipulation.
The odd thing is it's been just as hot other times and fired up just fine. It has never happened when I put gas in the tank but it's so random it's hard to say if that has any meaning.
PakRat is offline
post #10 of 13 (permalink) Old 07-08-2012, 09:29 PM Thread Starter
Yeah every time it happened after a heat soak.
PakRat is offline
