vacuum leak in intake 2011 XC - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 07-09-2012, 07:03 PM Thread Starter
Default vacuum leak in intake 2011 XC
I seem to have a vacuum leak at the throttle body adapter or the IAV hoses, surging idle with some stagger & sometimes will idle high. Sprayed brake cleaner around area & there is a leak somewhere, anyone seen this ? Oh also sounds like a shotgun firing on decel at times. Have VFC 3 & RPW Mufflers.
tr17047 is offline
post #2 of 2 (permalink) Old 07-09-2012, 09:27 PM
You can simply pull the cheese wedges and start moving those hose around to find out if one has a pin hole or slit in it.
Have you installed an IAV from Lloydz at any time?
BBob is online now
