Fuel tuner question - Victory Forums - Victory Motorcycle Forum
post #1 of 32 (permalink) Old 07-12-2012, 09:29 AM Thread Starter
Default Fuel tuner question
I have just purchased a used set of Stage 1 pipes for my Vegas and I already have the performance air filter and vent. Next step is a fuel tuner. Any suggestions on a reasonably priced, easy to install and easy to use one? I was looking at the Ness Cheap Shot, but I don't really want to splice into any wires. Looks like the Lloydz and Wiesco (?) one plug into existing connectors on the bike. Just wondering what people prefer.
Thanks!
2008 Victory Vegas Low (hers) - Boardwalk Blue
2013 Victory Cross Country (his) - Antifreeze Green
Lincoln, NE
swalker is offline
post #2 of 32 (permalink) Old 07-12-2012, 11:44 AM
07PEARLJACKPOT's Avatar
if you want to go the cheaper,easier way
take it to a dealer and have the stage1
download installed.
KURYAKYN LED BLINKERS
GUNFIGHTER SEAT
KURYAKYN FLAME COMFORTGRIPS
KURYAKYN FLAME PEGS
"JACKPOT" OIL COOLER COVER
CHROME STARTER COVER
MEMPHIS SHADES WINDSHIELD
VICTORY TOOL ROLL
RPW SLASH EXHAUST
S&S INTAKE
KURYAKYN ELLIPSE MIRRORS
07PEARLJACKPOT is offline
post #3 of 32 (permalink) Old 07-12-2012, 11:45 AM
half_crazy's Avatar
Get the Power Commander. Anything else can only add fuel and make for compromises.
2006 Victory Kingpin
half_crazy is offline
post #4 of 32 (permalink) Old 07-12-2012, 12:56 PM Thread Starter
Thanks for the input guys. I think the Power Commander is a little more product than I need. I really just need whatever it takes to make the bike run good. Not looking for huge performance. Just more sound. The Stage 1 download would be nice. Didn't know the dealer could do just that part for me. Any ideas what that would cost? I like cheaper, but I have a feeling my local dealer will gouge me on it.
Lincoln, NE
swalker is offline
post #5 of 32 (permalink) Old 07-12-2012, 06:11 PM
Some dealers some When I called my dealer and asked what I nneded to do to get a Stage 1 flash (I'd bought a set cheap), his reply was "Buy a set of pipes" Finally talked to Kate at Honda East and found out about $100 for the card, dealer will probably charge $100 - unless you get one who really likes to create relationships. I ended up gpoing the PCV route. $300 and I put it in myself. Spent an extra $100, but if and when I decide to do other changes I juts have to do another map (free).
"The motorcycle goes where you point your nose."
The Oracle
2011 XC, Stage 1, PCV, forged bars with pegs, 19" Cee Bailey Dragon windshield, 2" pull back bars, hard bags, saddle bag bars, rear trunk, lower deflectors, Baker Air Wings with uppers, front and rear bumpers, Stebel air horn.
Member of TOC
porchdawg is offline
post #6 of 32 (permalink) Old 07-13-2012, 09:10 AM
Atbyrne's Avatar
Go with power commander. Can do way more adjustments with it.
2011 Cross Country
PCV with Vic filter
Witchdoctors Muscle Mufflers
Painted inner fairing
Magnum 21" Wheel and Fender
Custom mounted CVO Tour Pak
Vicbaggers Bars, speaker grills,
and bezels
Atbyrne is offline
post #7 of 32 (permalink) Old 07-13-2012, 05:01 PM Thread Starter
So I got my pipes today and want to put them on. Will it cause a problem if I put them on and run them until I figure out what I want to do for a fuel tuner?
Lincoln, NE
swalker is offline
post #8 of 32 (permalink) Old 07-13-2012, 11:44 PM
coltman's Avatar
Your bike will run alot leaner with pipes and filter with no tuner. I just put on the Lloydz VFC III and really like it. It really smoothed it out and added a little more giddy up. I found the Lloydz on eBay for $189, I think they're $279 retail.
2013 Vision Tour
2012 Cross Roads (Wifes bike)
2011 Cross Country w/ tour pack. SOLD
Stage 1 kit.
Klockwerks flare windshield.
Windbreakers lowers.
Lloydz VFC III
Victory HID
2009 Vegas Low ( Wifes bike ) SOLD
coltman is offline
post #9 of 32 (permalink) Old 07-14-2012, 03:56 PM Thread Starter
Thanks for your input. Lloydz is the direction I am leaning. I've been looking around for a used one, but I'm sure they are hard to find. Especially the VFC III for the newer bikes. May just have to splurg on a new one, but sounds like I can run it without for awhile and not hurt anything.
Lincoln, NE
swalker is offline
post #10 of 32 (permalink) Old 07-14-2012, 04:19 PM
jaysonL's Avatar
Run just the pipes and keep the stock air cleaner, and unplug your o2 sensors. Bike will run fine. You'll get the occasional backfire, but that's common even with a tuner. I ran that way for a while and my fuel mileage was the same as it was with the stock pipes on. So, I'd say I couldn't have been too lean. Keep in mind. Your motor is a big air pump. If you don't take more air in, you can't really put more air out. Right ? Just keep the stock air cleaner on.
2009 Kingpin 8 Ball
Freedom Performance sharp curve radius pipes
Cross Roads bags mounted with Witchdoctor brackets
Kingpin tour tins
jaysonL is offline
