Help please, fuel issue - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 07-14-2012, 06:16 PM Thread Starter
OIFvet's Avatar
Default Fuel issue "fixed"!
My 2006 8 ball is not getting fuel to the cylinders. I've checked the bleed valve with the ignition on and gas only just runs out. Shouldn't this be under pressure? Ignition on and I hear the pump come on for 3 seconds or so and stop, sounds normal. I rode the bike yesterday without any issues. Then today it wouldn't start, cranks and hits a few times and that's it. It will run on starting fluid (I know, it's bad to do this, but I only tried it briefly to see). Battery voltage appears to be fine, even used a second battery when trying to start.
With this said, could it be the filter and if so how do I get to it? I don' have a manual. I figure it's that or the fuel pump seals. Somebody please give me a hand, I have searched till I am blue in the face. The bike has 28K miles and was running just fine yesterday. Yes, I am a newb, to victory cycles anyway.......I am already thinking of getting it running and selling it..
OIFvet is offline
post #2 of 13 (permalink) Old 07-14-2012, 07:52 PM
You might want to have your fuel pump pressure checked to see if its putting out properly.
2011 White XC with Trunk
OEM Bag Protectors
Cee Bailey Deflectors
Tall Windshield
Troll is offline
post #3 of 13 (permalink) Old 07-14-2012, 09:13 PM
kevinx's Avatar
Ethonal eats up the rubber parts in the pump on low mile to years bikes, and one day the regulator will just start bypassing. Sounds about like mwhat you have going on
kevinx is offline
post #4 of 13 (permalink) Old 07-15-2012, 12:43 AM Thread Starter
OIFvet's Avatar
Thanks for the replies, I will try to trace down the problem. Fuel pressure will be the first thing. Could anyone save me the search time and provide me with a link to fuel pump access/removal and rebuild. I am capable of doing the work myself, just don't have a manual. I work full time still (second career due to raising 2 grandkids now), so my time is very limited. Thanks again!
OIFvet is offline
post #5 of 13 (permalink) Old 07-15-2012, 05:53 AM
BBob is online now
post #6 of 13 (permalink) Old 07-15-2012, 06:46 AM
gibson's Avatar
fuel pressure is 51 PSI, if not like kevinx says
2012 Fireball Jackpot
gibson is offline
post #7 of 13 (permalink) Old 07-15-2012, 05:55 PM Thread Starter
OIFvet's Avatar
SitRep as follows:
1. With fuel line disconnected from "T", fuel pump comes on for approximately 3 seconds, then stops. Shouldn't it stay on since the line is open (no resistance to increase pressure)? There is pressure when it runs, so it is obvious that the pump is working.
2. When I had the tank nearly drained, I turned on the ignition, pump came on for the usual 3 seconds, then I could hear the fuel bypassing in the tank. This was with the fuel line disconnected (open).
3. Sounds like the pump is good, it is just a bypass issue or something of sorts.
That said, I have pulled the tank and ready to pull the pump. So does anyone hane an idea of just what I need to do, or have experienced this issue as well?
OIFvet is offline
post #8 of 13 (permalink) Old 07-15-2012, 05:58 PM Thread Starter
OIFvet's Avatar
Here ya go. Download this service manual to help out. Take a look at the parts manuals listed in the link in my sig line.
http://jumbofiles.com/nws64scvigw9
Thanks BBob. Looks like kevinx is spot on. Can I fix the regulator myself? Or just buy the regulator?
OIFvet is offline
post #9 of 13 (permalink) Old 07-15-2012, 07:26 PM
gibson's Avatar
http://www.thevicshop.com/Fuel_Pump_Assemblies.html need to call or check this out
gibson is offline
post #10 of 13 (permalink) Old 07-15-2012, 10:53 PM Thread Starter
OIFvet's Avatar
Originally Posted by gibson View Post
Thanks, this is probably what I will have to do. Athough I am fully capable of doing the rebuild (if I had instructions and parts), my wife is wearing me out....to say the least. Bottom line is that she thinks that I don't give her enough attention and I am always working in the shop and so on (all while she lays on the couch and watches chick flicks)......very frutstrating considering I clear about 6 figures a year and she doesn't even work. I can't have a single "toy". All she wants to do is go to the movies or out....spend $500 on a weekend and so on. I prefer spending my money on somethin to keep and enjoy, not waste it (guns, bikes, etc.). Honestly, after 26 years of marriage I have about had it. Yes I know, I am venting and this is all off topic. Sure someone else has the same issues. Stand by for a new thread!!
OIFvet is offline
