odd question revisited.. leak? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 07-16-2012, 07:49 PM Thread Starter
NJ8BALL's Avatar
Default odd question revisited.. leak?
A short while ago I post about having oil on the inside of my screen on my 09 8ball. Well, yesterday I came home after 120mile ride, parked the bike went upstairs. Came out 1 hour later for a smoke and look at my dusty bike, thanx dirt road. I noticed on the front wheel on the right side a pool of oil on the rim itself. If you straight up its the hub. I wiped around the bottom of the fork no oil.
Wth is happening? I know Im not seeing things lol
'09 Kingpin 8-Ball...Sanded chrome exhaust, Stage 1 slipons, VFCIII, Lloyds IAV, Stonny's 27" sissybar, Edge bags with ghost brackets,Kuryakyn black ISO grips,
http://www.bluebeardimagery.com/
http://blue-beard-imagery.artistwebsites.com/
Photo equip: Canon 60D, Canon 55-250is, Canon 18-55, Canon 70-200f4,Tamron SP10-24
NJ8BALL is offline
post #2 of 6 (permalink) Old 07-16-2012, 07:57 PM
kingslyzissou's Avatar
Maybe brake fluid? That's a strange one. Can the temp variance from being hot from riding, then cooling, exacerbate an underlying problem with a seal? I know its a stretch, but...
I'm interested to hear what experienced members will say.
2012 vegas 8ball
kingslyzissou is offline
post #3 of 6 (permalink) Old 07-16-2012, 10:00 PM
Jeepster's Avatar
Could it be the wheel bearing grease? Is it tacky or is it more like motor oil? What has your ambient air temp been?
'11 XC
Stage 1
Jeepster is offline
post #4 of 6 (permalink) Old 07-17-2012, 08:02 AM
MTVic's Avatar
Tears. Your bike wanted to keep going...
On the serious side, it is strange. Obviously has to be real slow leak since pooled AFTER sitting, or so I'm assuming. When you wiped it up, did you check the rest of the rim? Is there a light coating of "oil" fluid or whatever the liquid is around the entire rim? If so, leaking while riding.
You checked forks, check brake fluid level and open it to see if the color and viscosity match. Son't just look at it, dab a paper towel in it and take both out to the light.
Doubt bearing grease, should be thick enough to stay, even if extreme heat, would thicken again on rim after returning to normal temp.
Where you having a beer with that smoke or what were you smoking?
Mike
FORMERLY 2012 Black XC Tour
2016 Honda NM4
2014 Honda CTX 700 dct
MTVic is offline
post #5 of 6 (permalink) Old 07-17-2012, 02:28 PM
Sounds like some ass hole is playing a game with you
post #6 of 6 (permalink) Old 07-18-2012, 08:43 PM Thread Starter
NJ8BALL's Avatar
I doubt it was bearing grease it doesnt flow like this did.
Maybe it was tears lol
No assholes in my garage, cept me ha
Im taking a longish ride on sunday for a meeting. Ill keep checking it, but its confusing for sure. The brake fluid is good, I actuated the brake a number of times didnt see any leaks.
NJ8BALL is offline
