Corrosion causing Rear wheel to lose air - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 04-07-2015, 12:43 PM Thread Starter
howln's Avatar
Default Corrosion causing Rear wheel to lose air
Need help, this is the second time I've had a leaking rear wheel. It is from corrosion between the tire bead and the rim. anyone else seen this? Any coating I should try on the rim before remounting the tire? Any help greatly appreciated.
2006 Vegas 8 Ball; modified bars, peg brackets, air box; custom shift lever; OD pulley; tach; MS Batwing or MS fly screen; 2-1 pipe; 36k and counting
howln is offline
post #2 of 18 (permalink) Old 04-07-2015, 12:48 PM
LILMAGS500's Avatar
I would use a scotch brite cookie pad on my air powered die grinder and clean up the contact surface as good as possible and use a high quality bead sealer on it .
LILMAGS500 is offline
post #3 of 18 (permalink) Old 04-07-2015, 01:06 PM Thread Starter
howln's Avatar
Thanks, I figured on the scotch brite but never used a bead sealer. Any brand recommendations?
howln is offline
post #4 of 18 (permalink) Old 04-07-2015, 01:22 PM
LILMAGS500's Avatar
I have always got bead sealer for our shop from NAPA Auto Parts , if its good enough for our techs , its good stuff period .
post #5 of 18 (permalink) Old 04-07-2015, 01:30 PM Thread Starter
howln's Avatar
Appreciate the help.
howln is offline
post #6 of 18 (permalink) Old 04-07-2015, 08:56 PM
roadcouch's Avatar
I've had this problem with my car, I used to have it cleaned and sealed with bead sealer but the expansion/contraction of the tire would break the seal in less than 12 months. Done this this 3-4 times .I now found a shop to grind the corrosion down and rattle can enamel (spray paint) on the seal surface. The idea is the paint fills the porous material and seals it. Hope this helps.
roadcouch is offline
post #7 of 18 (permalink) Old 04-08-2015, 02:19 AM
BP6666VR's Avatar
All the above, but also consider to replace the compressed air with nitrogen the molecules are bigger then air molecules, also keeps the tire cooler, in asia it is common to fill tires with Nitrogen
Good idea for using a higher quality bead sealer ... I pay 5 $ to replace my rear tire so buying my own sealer would be a good idea ?
Cross Country Tour 2014 [B]
BP6666VR is offline
post #8 of 18 (permalink) Old 04-08-2015, 09:51 AM
Hogeyphenogey's Avatar
We used to sell the nitrogen at the last auto dealer I worked for. It will also help in lessening the moisture inside of the tire which is part of what's causing the corrosion along the bead. The bigger molecules will do a few things:
1. leak much less than regular air
2. change PSI readings to a much lesser extent when changing altitude and temperature.
3. in case of a blowout, it is usually less traumatic and in the event of a nail getting stuck in the treads, it may actually not leak much at all compared to regular air.
Tour de France riders use it, military uses it, race cars use it... we should too!
A sunny day and a full tank of gas- my little slice of Heaven!
2015 Gunner
2011 Triumph Thunderbird Storm
2010 Triumph Thunderbird
2008 Triumph Sprint ST
2006 Yamaha VStar 1100 Custom
2000 Suzuki SV650
1985 Suzuki ES550EF
Chicopee Massachusetts
Hogeyphenogey is offline
post #9 of 18 (permalink) Old 04-08-2015, 10:46 AM Thread Starter
howln's Avatar
Thank to all, I'll try the nitrogen
howln is offline
post #10 of 18 (permalink) Old 04-09-2015, 02:42 PM Thread Starter
howln's Avatar
Default wheel corrosion
one pic is of the tire, forgot to get a pic of the wheel before, but you can see the result. the other is after 3 hours of grinding and polishing. I'm thinking of using a clear coat paint on the inside of the rim; any suggestions would be greatly appreciated. after numerous bikes and riding since 1971 this is the first wheel I've ever had get this bad. Thank in advance for all the suggestions.
Forgot to add, no nitrogen in my area.
howln is offline
