ready to junk piece of crap dike v92sc 1999 - Victory Forums - Victory Motorcycle Forum
post #1 of 25 (permalink) Old 07-22-2012, 04:56 PM Thread Starter
Unhappy ready to junk piece of crap dike v92sc 1999
I have had this bike going on 5 years now i love the bike its a perfect fit for me the problem is it is totally unreliable never no if it is going to start and if it does if your going to get to your destination when it does start you get about 1 or 2 miles down the road at a speed of about 55 to 60 mph it will sputter then shut down most of the time you pull over down shift to neutral turn of key wont restart if you dont turn key back on start bike and go. lately when i start bike it will fire up run for 5 or 10 seconds shut of on its own and then wont start for a day or 2 at all been away from home when this happens have to find a hill push it there and roll down and pop the clutch to get it running this happened on Thursday Friday morn I started it to ride to work made it just over 3 miles before it sputtered and shut down. I went through normal restart up procedure it started I shifted into 1st let out the clutch heard god awe full noise from lower back end blew a drive belt is there no end to this crape have had it in repair shop every summer for a C notes worth of repairs ready to junk it
Big Dog victory is offline
post #2 of 25 (permalink) Old 07-22-2012, 07:58 PM
Default engine compression
i wonder if its a cylinder compression problem?? When its cold, it starts and as it heats marginal compression becomes worse. Strange one
marconewt is offline
post #3 of 25 (permalink) Old 07-22-2012, 08:38 PM
half_crazy's Avatar
If you decide to junk it, let me know... I'll come get it.
Your issue is probably something simple, you just haven't found anyone who is simple enough to figure it out.
Seriously, it is tough to diagnose an intermittent problem.... but not impossible. Stay with it.
2006 Victory Kingpin
half_crazy is offline
post #4 of 25 (permalink) Old 07-22-2012, 10:40 PM
Tims_04V92TC's Avatar
Fire or gas.. Have you pulled a plug when it wont start? Damp? When you had it in the shop have they checked your fuel pump pressure. If not, something to think about, I would be leaning more towards the fuel pump from your description.
Im with Half Crazy, if your wanting to dump it....
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #5 of 25 (permalink) Old 07-24-2012, 12:43 PM
Sounds like a loose/damaged wire. Or bad sensor?
8-Baller is offline
post #6 of 25 (permalink) Old 07-25-2012, 08:34 AM
06vitory's Avatar
Have you taken apart all of your wire connectors and look for any corrosion? Then clean and apply some D/ E greese. Intermittent problems could be as simple as a bad/ loose connection.
2006 Kingpin Deluxe
Stage 1 pipes
Dunlop D407 & D408 tires
06vitory is offline
post #7 of 25 (permalink) Old 07-26-2012, 03:04 PM
It sounds like it is electrical in nature if your bke all of a sudden cuts out completely when you are cruising down the road. It is probably a bad starter relay or voltage regulator. I had the same problem on an 89 superglide.
knucklehead is offline
post #8 of 25 (permalink) Old 07-26-2012, 04:03 PM
OkieHoss's Avatar
your so full of shit...You love the bike for 5 years you say---> i love the bike its a perfect fit for me---> but yet it is unreliable does all these bad things to you and you list a random bs list of things that happen to you and yet have not fixed the problem in 5 years ....I call bullshit you are obviously tring to dog Victory ..
2013 black XCT.
OkieHoss is offline
post #9 of 25 (permalink) Old 07-26-2012, 04:44 PM Thread Starter
Angry not dogging victory
no i am not dogging victory bikes but i have had this bike for five years had it in 3 different repair shops in including a victory dealer ship never less than 500 to pay for the repairs or so called repair get the bike home ride for a week or two only to have it happen again the guys at my shop place bets on weather its going to start when i go home and believe me i always pray that it will so to stop being the but of there jokes the longest time it was in a shop was almost 2 months paid 750 for a fixed bike only to have it shut down on way out of the driveway and 2 days later shut down doing 70 mph with a tractor trailer behind me and then 3 days later had id towed back to shop wouldnt run at all in shop another 3 weeks so im sorry if i sound negative but dam how much would you take
post #10 of 25 (permalink) Old 07-26-2012, 05:14 PM
If the dealer people are laughing at you and taking bets then they know they didn't fix your bike. Sounds like you're being ripped off to me. Time to find someone else maybe that can help you.
I'll get cussed out too but Okie that was uncalled for!
Now owns 2012 Cross Country Tour! 3-9-12
http://patsrides.blogspot.com/
pat0021 is offline
