fuel additives - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 04-09-2015, 10:45 AM Thread Starter
Unhappy fuel additives
Ok, This has already been discussed but I missed it I'm sure. What is the best "Fuel Additive " if you think you may have bought bad gas??
2014 JackPot
STONEFACE is offline
post #2 of 9 (permalink) Old 04-09-2015, 11:00 AM
put in as much as you can new gas. Additives are just snake oil
get the app pure gas now at your finger tips you can have good gas.
post #3 of 9 (permalink) Old 04-09-2015, 11:38 AM
Bigmike17's Avatar
Run to harbor freight and get a $7 transfer pump and pump it into a gas can for use in the lawnmower. You should be able to get Pure gas at one of the Marinas close by to run.
http://pure-gas.org/index.jsp?stateprov=FL
2014 Cross Country Tour
Freedom Performance exhaust, Lloydz VFC and a Lloydz Intake/filter, Lloydz ATS.
Bigmike17 is offline
post #4 of 9 (permalink) Old 04-09-2015, 12:14 PM
Pjv1k's Avatar
Never had any issues using it or not using it but the stuff at Walmart star tron I think it's called has been used by me and friends and never let me down
2014 Pearl White cross country
2011 Mini Cooper Clubman S
Pjv1k is offline
post #5 of 9 (permalink) Old 04-09-2015, 12:44 PM
+1 on replacing with fresh gas. If the gas presently in your tank is more than a month old and does not have a stabilizer in it, the volatility has diminished and won't ignite well. The only thing you want to put into gas is a stabilizer if you're not going to be using that engine for a month or more.
post #6 of 9 (permalink) Old 04-09-2015, 05:15 PM
ditech's Avatar
Any one use victory carbon clean additive?
ditech is offline
post #7 of 9 (permalink) Old 04-09-2015, 05:54 PM
what makes you think you have bad gas
post #8 of 9 (permalink) Old 04-09-2015, 06:20 PM
spanknut24's Avatar
Gives himself a dutch oven.
06 Kingpin..
K&N air filter
Victory Drag Pipes
ATS @ +4
VFC III
Tuned by KMC
08 vision premium.. totaled :(
06 kp traded in.
04 vegas lost in flood 2010.
06 hyosung traded in for vegas.
spanknut24 is offline
post #9 of 9 (permalink) Old 04-09-2015, 06:49 PM
Nothing will fix bad gas. You have to replace it. Stabilizers are good for storing gas but will not fix bad gas. As suggested earlier, get a pump and siphon as much out as you can. But don't mess up your lawnmower by using the bad gas in it.
Gdfishwell Galveston,Tx 2008 Kingpin Tour Lloyd's timing wheel set at +3degrees, kuryakyn isogrips, kuryakyn throttle lock with matching left side bar end weight
gdfishwell is offline
