Regulator and fuel pump cross reference - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 07-23-2012, 11:22 AM Thread Starter
cornfedboy2000's Avatar
Default Regulator and fuel pump cross reference
I have a 2001 v92c. Does anyone know if the fuel pump and regulator are year specific, or will newer models work? I'm having a hard time finding older versions. Thanks
cornfedboy2000 is offline
post #2 of 7 (permalink) Old 07-23-2012, 05:26 PM
Try the Vick shop he does fuel pumps
witch regulator do you mean
http://thevicshop.com/
post #3 of 7 (permalink) Old 07-23-2012, 05:57 PM Thread Starter
Sorry, I meant the voltage regulator.
post #4 of 7 (permalink) Old 07-24-2012, 08:36 PM Thread Starter
I read a post by KevinX eluding to a fuel pump for a mazda rx7 working.... anyone know if that would work? He also mentioned that the fuel pressure should be at 49 psi, is that strictly driven by the fuel pump or is there a pressure regulator in the system. So far my only options are break the bank on a new pump at 175-225$ or buy a used one off ebay and not know if it will die right away.
post #5 of 7 (permalink) Old 07-24-2012, 08:41 PM
Tims_04V92TC's Avatar
Don't go used dude... Your peace of mind will be out the window and you will never know what you really have. Had to bite the bullet a couple months back on the Cage and I will say it hurt the wallet however, truck runs great and there is no question what I have in the tank. Just my two cents if you go that route.
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #6 of 7 (permalink) Old 07-24-2012, 08:46 PM Thread Starter
there is a pressure regulator in the system, so now the question is... what is the actual pressure of good OE pump... anyone know that? If I can figure that out I can figure out if a different pump would work.
post #7 of 7 (permalink) Old 07-24-2012, 08:47 PM Thread Starter
yeah, I'm definitely steering away from used
