Brake Question - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 04-11-2015, 03:37 PM Thread Starter
Tenac's Avatar
Default Brake Question
My rear brake rotor has a little play in it. Hard to describe but its front to back (froward and reverse) of bike. I know these are floating rotors just wondering if its normal for them to move about 1/4" front to back (not side to side). Front rotors do not move like this. Thanks for the info.
2008 Hammer
LED
2 into 1 No baffle
Lloydz intake
Power Commander 3
CHROME
Speakers
Tenac is offline
post #2 of 6 (permalink) Old 04-11-2015, 07:00 PM
are you sure 1/4" never seen one that bad.
You have your front rotor to compare the movement to.
The rear should have the same amount of movement as the front
Should move maybe 1 or 2mm no more
post #3 of 6 (permalink) Old 04-12-2015, 11:04 AM
45caldan's Avatar
Mine wiggles quite a bit and rattles when I hit bumps....
New one needed???
Any way to tighten up the buttons???
2010 Cross Roads
Vic HP air filter
Stage 1
D&D slash cut mufflers
Lloyd's Adjustable Timing Wheel @ 4
Kuryakyn Engine Guard Driving lights
Sabertooth auxiliary tail lights
7jurock custom WS with vent
Cee Bailey lowers
Ness Tear Drop mirrors
45caldan is offline
post #4 of 6 (permalink) Old 04-14-2015, 07:38 AM
soofle616's Avatar
floating rotors should move side to side ONLY. If the rotor moves forward or back relative to the carrier or if the buttons spin the rotor is shot and needs to be replaced.
That said, how are you checking the front/back 1/4" of movement? Are you putting hands on the rotor and rocking the disk back and forth or stepping on the pedal and pushing the bike. If the latter I would check that the caliper is securely mounted and if so i would check that your pads aren't wobbling around in the caliper as those are more likely to cause the bike to have some wiggle room than a worn rotor.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #5 of 6 (permalink) Old 04-14-2015, 01:38 PM
45caldan's Avatar
Ordered a rotor...
2010 Cross Roads
Vic HP air filter
Stage 1
Cee Bailey lowers
45caldan is offline
post #6 of 6 (permalink) Old 04-15-2015, 06:56 AM Thread Starter
Tenac's Avatar
Sorry for late response been busy, I just put my hand on it and can move it front to back of the bike not side to side. The front don't really move at all... I guess I better just order a new one.
2008 Hammer
LED
2 into 1 No baffle
Lloydz intake
Power Commander 3
CHROME
Speakers
Tenac is offline
