2012 XCT - Low Beam HID Headlight - Intermittent Problem - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 04-13-2015, 07:20 PM Thread Starter
Default 2012 XCT - Low Beam HID Headlight - Intermittent Problem
The HID low beam headlight on my 2012 XCT stopped working last night right at the end of a long (10 hr) ride at high speeds (80 mph). I rode in the rain most of the day (6 of the 10 hrs) but when the light stopped working, we had been out of the rain for more than an hour. I figured the bulb just went out. Tonight I went out to take it apart and see what bulb I needed and the bulb was working.
Any ideas on what would cause the light to stop working last night and start working tonight would be appreciated.
I am certain that the low beam light would not work and that the high beam light did work. I turned from high to low beam on a dark country road and it was pitch black in front of me. I also had several cars flash their brights at me to indicate my high beam was on.
G'day,
Vinish
Vinish is offline
post #2 of 4 (permalink) Old 04-13-2015, 07:44 PM
deadduck's Avatar
Could be corrosion/moisture at the hi/lo switch?? Kinda a common problem on the old BMW bikes don't know about Vic's yet.
I'm curious to know what you find because I have the same model year xct
2012 cross country tour
Modded stock exhaust (Jones a3512b)
PC 5
K&N pl1500
noise seal removed
Lloyds timing wheel at +5
Klock Werks flare windscreen
2004 Buell XB12r
1985 BMW K100RT
deadduck is offline
post #3 of 4 (permalink) Old 04-13-2015, 08:52 PM
kodiakwood2's Avatar
Crazy, similar story here, my low beam went out the other day so I rode with my hi beam on, got home to check it out and everything was fine,, double checked all the connections.
Hasn't happened since.
Eastern Tennessee
Current ride
2018 Goldwing tour
Gone but not forgotten...
Black/Chrome
Ultimate seat and driver backrest, Vic passenger backrest, Custom pinstriping by Dave Davies
Lloyds PTS @+5, Lloyds air filter, PC-V, Miller Mufflers, Lloyds Dyno-Tune,
Lloyds quarter turn throttle ring, Victory HID's, RicZ lay down bracket, Barnett "Stealth" clutch cable
kodiakwood2 is offline
post #4 of 4 (permalink) Old 04-13-2015, 09:21 PM
2012 CCT here as well. LOTS of miles in the rain but my factory HID low beam did go out on one particularly strong frog strangling downpour. It came back on soon after the rain stopped.
All the best,
Mark
www.bikersforchrist.org
"That's a beautiful Victory!"
"Thank you."
"Who makes it?"
"No one."
Chattanooga Mark is offline
