Gearshift and brake adjustment - Victory Forums - Victory Motorcycle Forum
 2Likes
  • 2 Post By skidooboy84
post #1 of 5 (permalink) Old 07-30-2012, 09:41 PM Thread Starter
Archer's Avatar
Default Gearshift and brake adjustment
Because of mt JTD lowers install I needed to move my brake lever and shift lever to the rearmost position. The brake side went smoothly however the shift side is giving me problems. Even after I adjusted the linkage as far as it would go the lever itself was still way too tall. Approximately 5" from the floorboard whereas the manual calls for 3.65". So I tried to adjust it at the tranny by pulling the whole linkage off and moving it a few teeth counter clockwise. This worked as far as shifter height however now it makes a really, really hard "clunk" when I shift into first and it wont even upshift past neutral so obviously I need to return that to its original position......which puts me back to my original problem. The shifter peg is way too high. Am I doing something wrong? I thought I did this per the serrvice manual. Any thoughts would be helpful.
Fyi...I only tested the shifting with the bike parked but running. I never started to move. It's still apart for my lowers wiring install.
Thanks!
Chris
2011 White/silver XC
Arlen Ness Big Honkers
PC V with custom dyno-tune by Kevinx (110 hp 114 tq)
VictoryHID.com ugrade
Lloyds VM1-DR cams
Lloydz timing wheel (+6)
Lloydz Perfomance filter
1/4 turn throttle ring
Rockford Fosgate amp
jtdcycleparts hard lowers
Archer is offline
post #2 of 5 (permalink) Old 07-30-2012, 10:50 PM
NOEMTZ's Avatar
You have to cut about 3/8" off each end of the rod, the file down burrs. Leave nut threaded on so you can run it down to check ease of threading.
www.noemtz.com
NOEMTZ is offline
post #3 of 5 (permalink) Old 07-31-2012, 08:35 AM
Hmmmmmm....I just adjusted mine the other night, but the other way. I moved mine to the front-most setting. Of course that put the shifter way too low. The linkage wasn't long enough to get the peg to the right height so I adjusted it at the tranny...moved it a couple teeth clockwise. It seems to shift fine...haven't noticed any problems. Am I going to hurt it by doing this? Should I go buy a longer linkage? The manual didn't specify.
2012 Cross Country -
--Atom Bombs
--Lloydz timing gear
--Lloydz air filter
--Power Commander
SOLD -- 2007 Kingpin Tour - Bassani 2>1's - The Vic Shop's 100/6 hop up kit
JFeisty is offline
post #4 of 5 (permalink) Old 07-31-2012, 08:59 PM Thread Starter
Archer's Avatar
Thanks for the tip. Ill have to give that a try
Lloyds VM1-DR cams
Archer is offline
post #5 of 5 (permalink) Old 05-08-2017, 07:12 AM
I know this is an old post, I took 3/8" off each end and it worked perfectly. Thanks for the tip.
NOEMTZ and Motorbikerx like this.
skidooboy84 is offline
