brake fluid question, dot 4 or dot 5? - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 07-30-2012, 11:46 PM Thread Starter
dtmmil's Avatar
Default brake fluid question, dot 4 or dot 5?
The master says to use Dot 4, can we use Dot 5? or should we stick with Dot 4? I am getting a set of 4" forward relocation brackets so I will be opening my lines to add the extension so I will need to add more fluid. thanks
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #2 of 4 (permalink) Old 07-31-2012, 08:19 AM
handyhoward's Avatar
Using DOT 5 in a DOT 3 or DOT 4 system without proper flushing will cause damage to the seals and cause brake failure.
DOT 5 brake fluid is not compatible with anti-lock brake systems.
DOT 5 brake fluid absorbs a small amount of air requiring care when bleeding the system of air.
Handy
2013 Indian Vintage Chief FE... #7 of 25
2011 Victory Vision Tour Premium...
handyhoward is offline
post #3 of 4 (permalink) Old 07-31-2012, 06:33 PM Thread Starter
dtmmil's Avatar
Gotcha, thanks!
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #4 of 4 (permalink) Old 07-31-2012, 07:54 PM
gibson's Avatar
Why? I don't get some people on any these forums.
2012 Fireball Jackpot
gibson is offline
