Brake issue. Need help - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 04-26-2015, 08:25 PM Thread Starter
Default Brake issue. Need help
Hello,
I have a 2000 v92c and I removed the rear brake line by the pedal to move the line out of the way of the exhaust. PO work. I can't get the brakes to bleed correctly now. When I get fluid out of the hose I attached to bleed the brakes its full of air and won't stop. Now I get nothing. No fluid to come out at all. I don't know what is going on. Can't see any leaks or anything.
Thanks.
Mark.
Savage1973 is offline
post #2 of 7 (permalink) Old 04-26-2015, 10:20 PM
www.speedbleeder.com I never had a more firm lever or an easier bleeding operation. I wish they had been invented 60 years ago.
Oh, and Mark, please complete your profile and a signature. That will help us to help you.
post #3 of 7 (permalink) Old 04-27-2015, 12:43 AM
BP6666VR's Avatar
Did you get the air out already mate ?
Cross Country Tour 2014 [B]
BP6666VR is online now
post #4 of 7 (permalink) Old 04-27-2015, 04:03 AM
gibson's Avatar
the master cylinder lost it's prime. did you let the fluid run out of it? if you did you will never get it to bleed. reprime the master cylinder and it should fix your problem.
https://www.youtube.com/watch?v=tkxcQzhgJLU
2012 Fireball Jackpot
gibson is offline
post #5 of 7 (permalink) Old 04-27-2015, 06:53 AM
Motorbikerx's Avatar
Yeah thats right, never let your master cylinder empty while bleeding brakes or its back to square one and worse.
Check the connection where you disconnected it.
Make sure its not cross threaded and if it is youll need to remedy that. If its ok then make sure its tight then rebleed thr system with fresh brake fluid.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 7 (permalink) Old 04-27-2015, 07:15 PM Thread Starter
This helped, got it now. Thanks!
post #7 of 7 (permalink) Old 04-28-2015, 05:24 PM
I love a happy ending to a tale of woe.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
