ATS Help - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 04-27-2015, 07:54 PM Thread Starter
Default ATS Help
I have decided to install the LLoydz ATS, and of course nothing goes smooth like Paul's videos (joking) but my real problem starts when I had removed the center bolt and trying to take the stock wheel out. The wheel does not move, no wiggle back and forth, no nothing, no movement whatsoever. What would you advise to do now?
2014 XCT, Utopia Backrest, Guard Dawg, Longhorn brake pedal, ISO Longhorn shifter, Arlen Ness gas cap, VM-1 Cams, Lloydz ATS, Lloydz air filter, PCV, Madstad Windshield, Victory HID, Vance & Hines Hi-output. 118/120 Dyno tuned by Kyle.
Jlvazquez6 is offline
post #2 of 4 (permalink) Old 04-27-2015, 08:45 PM
BP6666VR's Avatar
I think you should read this tread below
https://www.victoryforums.com/showthread.php?t=40274
Cross Country Tour 2014 [B]
BP6666VR is offline
post #3 of 4 (permalink) Old 04-27-2015, 10:08 PM
Scotchbriar's Avatar
I had the same problem that you described. I used a a piece of metal as a pry bar to break it loose just a smidgen so I could wiggle it. After that I carefully wiggled it with my hands until it came loose. I've heard from some on here that they can be a little tough to remove. Be patient and go easy with any pry tool.
Good luck!
2013 Victory Cross Country
Victory Motorcycle Club Treasurer
River Cities Victory Riders (RCVR)
Secretary/Treasurer
www.rcvrclub.com
Scotchbriar is offline
post #4 of 4 (permalink) Old 04-27-2015, 11:26 PM
Mine was a little tough also - but with some pressure slowly it gave in and all went smooth after that...:^)
2012 Cross Country Tour - VroomHilda
Dobeck EJK Gen3 Fuel Tuner
Tri Flo Ovals
Vic K&N knock off Air filter
Lloyds Timing Wheel +2
Relocated Air Shock fill hose
WD SkidPlate reinforced
Hyper running/brake lights
Garmin GPS
Existential Secular Humorist with warrior Buddhist leanings
*Rider/Owner continuous since 1973 - 877,000+ miles USMC R
SemperVee is offline
