changed oil and spark plugs, wont idle - Victory Forums - Victory Motorcycle Forum
post #1 of 38 (permalink) Old 04-28-2015, 02:03 PM Thread Starter
HVAC's Avatar
Unhappy changed oil and spark plugs, wont idle
So I changed the oil and the spark plugs and now when I start it up it "idles" from 200-400rpm for about 4 seconds then dies. Fortunately once it warms up it's fine but I have to use the fake choke (or the throttle lever or whatever it's called) which I've never had to use before unless it was snowing outside. It is also backfiring and I feel like there is a loss of power on the low end. I got the spark plugs and the oil from the Victory dealer. It does have a Lloyds programmer too but I haven't touched it in a long time. I know it isn't urgent because it does run and idle fine when it's warm, but I'd just like to find out whats going on with it. Any help is appreciated!
2009 V-Star 650 (had for 6 months) - sold
2006 Victory Hammer
HVAC is offline
post #2 of 38 (permalink) Old 04-28-2015, 02:27 PM
DillPickle311's Avatar
My guess is if it was fine before, it's not the oil but the plugs. If you still have the old ones, stick them back in there and see if a difference.
DillPickle311 is offline
post #3 of 38 (permalink) Old 04-28-2015, 02:39 PM
LILMAGS500's Avatar
Reverse your plug wires , your timing is probably off 180 degrees .
LILMAGS500 is offline
post #4 of 38 (permalink) Old 04-28-2015, 02:40 PM
I was thinking the same thing!
post #5 of 38 (permalink) Old 04-28-2015, 03:37 PM
Travis P's Avatar
What Mags and Broggy said...
Travis P is offline
post #6 of 38 (permalink) Old 04-28-2015, 06:03 PM
How did you pull the plug wires. I bet you pulled a wire out of the metal connector
oil has nothing to do with the bad idle. Your PCV might have gone bad
post #7 of 38 (permalink) Old 04-28-2015, 06:12 PM
I was thinking the same about the wires. When they heat up from the motor it could be causing just enough expansion to make good contact again and the bike runs normal.
Another thought could be incorrect plug gap, same idea with the thermal expansion. It's a little more far fetched but still a possibility.
Blake is offline
post #8 of 38 (permalink) Old 04-28-2015, 07:22 PM
I'll vote for the damaged wires. Low or no spark on one of the cylinders.
Not all those who wander are lost.
2011 Kingpin
53canuck is offline
post #9 of 38 (permalink) Old 04-28-2015, 07:34 PM
rhino 2's Avatar
Mechanics, 101...... Go back to the last thing you changed..
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #10 of 38 (permalink) Old 04-28-2015, 08:03 PM
ndabunka's Avatar
Spark plug GAP seems to be the most BASIC element of this situation. Did you check the gap or did you simply pull them outta the container and slap them into the bike? Not certain about new plugs but in the old days (25+ years ago) it was fairly common that the plugs needed to be checked for CORRECT gap clearance before replacing.
It's not just any victory.... It's MY Victory!
2011 Victory Ness Cross Country #120
Ness Thunderheaders
Ness Knurled Highway Pegs/KwelMetal Brackets
Ness Radius laydown license
Chrome CAM Tension Covers
Red Engine Bolts
Madstad System
DIY Garage Door Opener
Victory Chrome Saddle Bag Lid Rails
Küryakyn Upper Fork Shrouds
Küryakyn Lower Fork Covers
Power Commander V Tuner
Power Commander AT-300
Hertz HCX 165s Speakers
JL Audio HX280/4 Bridged 140w
ndabunka is offline
