After Timing wheel, PC-V and air filter what gas grade to use? - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 04-28-2015, 10:48 PM Thread Starter
Dos_Equis's Avatar
Default After Timing wheel, PC-V and air filter what gas grade to use?
Hello Team:
I have always use medium grade gas (89). After installing the timing wheel (6+), PC-V with custom map, Hi-flow air filter and drilled baffles, do I need to use premium grade gas? Today was the first time I fill with premium and it feels like the performance of the bike diminish. I like to ride the bike hard and upshifting above 4000RPM's. whit the premium gas bike feel slower, not sure if is my imagination. Any ideas?
Thank you.
2013 Cross Country (Sunset Red)
-- Rusty Jones Customs mod mufflers, Power Commander-V, Lloydz Hi-Flow Air Filter, Lloydz ATS @ 6+, Tarzanz Bagger barz.
Houston, TX
Dos_Equis is offline
post #2 of 13 (permalink) Old 04-29-2015, 02:56 AM
ndabunka's Avatar
Originally Posted by Dos_Equis View Post
Hello Team:
Thank you.
Why would you change your fuel if you didn't change the COMPRESSION of the engine any? Just go back to regular (you don't even NEED mid-grade as Victory bike's are designed to run "just fine" on regular
It's not just any victory.... It's MY Victory!
2011 Victory Ness Cross Country #120
Ness Thunderheaders
Ness Knurled Highway Pegs/KwelMetal Brackets
Ness Radius laydown license
Chrome CAM Tension Covers
Red Engine Bolts
Madstad System
DIY Garage Door Opener
Victory Chrome Saddle Bag Lid Rails
Küryakyn Upper Fork Shrouds
Küryakyn Lower Fork Covers
Power Commander V Tuner
Power Commander AT-300
Hertz HCX 165s Speakers
JL Audio HX280/4 Bridged 140w
ndabunka is offline
post #3 of 13 (permalink) Old 04-29-2015, 04:04 AM
LILMAGS500's Avatar
The sticker on my tank says to use at least 91 octane , regular around here is 87 . No way in hell would I use that , I'm strictly 93/94 , highest available when I need fuel .
LILMAGS500 is offline
post #4 of 13 (permalink) Old 04-29-2015, 04:07 AM
LILMAGS500's Avatar
Originally Posted by ndabunka View Post
Why would you change your fuel if you didn't change the COMPRESSION of the engine any? :
Because he advanced his timing quite a bit ... Low octane fuel will cause major pinging and engine damage .
post #5 of 13 (permalink) Old 04-29-2015, 05:30 AM
I've always run "premium"(91-93 oct) grade fuel in my bike, even stock. Mostly because(I believe) the premium has better detergent and cleaning agents in most brands.
On the other hand, I know broggyr has his ATS set to +7 and he runs 87oct fuel with no problems or ping issues.
post #6 of 13 (permalink) Old 04-29-2015, 10:10 AM
Blowndodge's Avatar
I've always ran regular with the stage one filter and it's never ran hot or pinged. Premium gas has no additional detergent or mystical cleaning agents over regular. Premium only has an additive so that spontaneous combustion (dieseling) doesn't occur.
2013 Victory XCT. Lakewood, CA
Russell Day Long Saddle.
7Jurock 14" tinted flip shield
Unplugged O2 sensors.
Stage one filter.
14" replacement ant.
Drag Specialties highway pegs.
Custom Pin-striping.
Blowndodge is offline
post #7 of 13 (permalink) Old 04-29-2015, 10:15 AM
Sorry Blowndodge, the difference is this; The higher the octane number, the slower (longer) the burn. Regular burns faster, that's why it has a greater tendency to ping in higher compession engines.
RICZ is online now
post #8 of 13 (permalink) Old 04-29-2015, 10:25 AM
Slight correction:
I'll run 87 in the early spring and late autumn. When it's hot, I'll put 91+ in it...
post #9 of 13 (permalink) Old 04-29-2015, 10:45 AM
6 degrees I think is to much with the ATS when all the builders are setting the timing at +4
91 octane is good for plus 95 degree days and running up hills and mountains. For normal city riding and going threw the countryside 87 or 89 is fine if your not pinging.
87 or 89 octane will cause less carbon build up on your pistons and valves
post #10 of 13 (permalink) Old 04-29-2015, 02:20 PM
Blowndodge's Avatar
You obviously didn't read my post carefully. Additives are added to premium so that the spontaneous (igniting fuel without the aid of a spark) is reduced. Slower burn times show a lower energy output to Premium. You want the fastest burn time without spontaneous (pre-ignition) happening. If your bike doesn't ping on regular using premium with it's "slower" burn time is reducing power.
Stage one filter.
